Question about ASUS Eee PC 1000H Laptop
How to disable keypad or at least decrease the sensitivity of it. While typing, it makes cursor jump if accidentally touched.
    Guru:
  • 689 Answers
You might be able to do this from your "settings" option. If this doesnt work and you get auto-downloads from asus they will update this sensitiviity problem with patch,enable downloads first then wait and see if the update is there,
Posted on Sep 04, 2010
My cursor jumps all of the page when I'm typing on my Gateway NV76R45u laptop. what am I doing?
I was having a similar issue with my laptop. What I found was while I was typing, my thumbs were close enough to the "Touch Pad" to move the curser. You can decrease the sensitivity or disable the touch pad (which I do when the external mouse is connected) Let me know if this helps.
Dec 05, 2014 | Gateway Computers & Internet
Cursor jumping
I have had this same issue. I realized one day that the palm of my hand was touching the track pad intermittently. Some of the HP laptops have super sensitive track pads. Mine actually has a button that disables it for typing. let me know, if this helps.
Feb 26, 2013 | HP Computers & Internet
Cursor jumps around
Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Jan 28, 2013 | Dell Inspiron dncwix12 Notebook
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
Next to impossible to type on Samsung N150 Plus netbook. Cursor jumps all over the place and words insert themselves in other words, etc. Also, have to be conscious of where the cursor is when replying...
There should be a way to reduce the sensitivity of your touch pad. Check your manual. There might be an application in your control panel. Check there too.
Oct 07, 2010 | Samsung N150 (36725723009) Netbook
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
Jumping letters on acer laptop when I type
You need to disable the touch pad while typing. During typing your palm can accidentally touch the touch pad causing the cursor to 'jump' randomly resulting in the problem.
You have not mentioned the model but on Acer laptops there's a key in the upper row with a 'pad and finger' figure on it. If the figure is in blue, press Fn together with the figure key to disable the touch pad and then again to enable it.
Mar 31, 2010 | Acer Computers & Internet
Acer aspire 5520-5334
I had the same problem. It is due to the touch pad being to sensitive. My fix was to buy a usb mouse, and disable to trackpad by hitting the Fn key and F7. No problems anymore
Apr 02, 2008 | Acer Aspire 5520-5908 Notebook
ASUS Eee PC 1000H Laptop Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
