Question about Eclipse CD2000 CD Player
How to turn on aux input on cd 2000 - Eclipse CD2000 CD Player
Cd player on 2006 f150 makes a clicking noise and gives a cd error when i turn the vehicle on. the cd changer is empty
sounds like the unit is stuck in ship mode
or the loading gear is bad they make click click like 5 times
radio needs to be repair there is no easy fix for this
the other solution is just leave along and trasfer all your cd's to mp3 or ipod
there is factory auxiliary input for ford radios with the AUX button
http://www.oemautosound.com/pc-192-86-frd04-aux-ford-2004-and-up-input-audio-adapter-aux-button.aspx
Nov 23, 2010 | Car Audio & Video
I have my Kenwood CA-C2AX audio cable plugged into my Kenwood KDC-MP228 CD reciever. I switch it to AUX-EXT and I still dont get any sound.
you have to go into the radio menu and turn off the cd changer port, keep scrolling auntil you find the aux input turn it on
and the audio input will woork
good luck
Mar 04, 2010 | Kenwood KDC-MP228 CD Player
Cannot find the choice for aux input in order to attach iPod
put on standby mode. then hold in "menu" button.
go through the list by pushing the right hand trigger down. there should be an option aux1. change this to turn on and aux input is on the source option.
Jan 25, 2010 | Kenwood KDC-W3037A CD-receiver,...
How do you turn on the AUX input on my avic-d2
the aux inputs will not activate unless you plug an accessory in like a CD changer into the digital input.
Dec 22, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
I cant figure out how to get an MP3 player to play through my CD player....it has 3 different audio rca jacks in the back...i try all three none worked....is there an AUX setting that need to put my cd...
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
Jul 28, 2009 | Car Audio & Video
Pioneer DEH-P1Y won't recognise AUX input
turn unit off then push jog wheel for 3 seconds new menu comes up and you will find aux setting set to on and you be all good
Jul 13, 2009 | Pioneer Car Audio & Video
All I need to know is how to change a CDX_CA700 CD player to AUX
On the Sony unit (CDX-M100TF) you need to activate the AUX input from the stanby screen. It may work with yours as well...its worth a try!
Turn stereo "off". Press menu and there's an option for the AUX input.
Note: This may not be accesible when the stereo is 'on'.
Jun 29, 2009 | Sony CDX-CA700X CD Player
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Using Aux Input in a Pioneer AVH-5700DVD
I'm not sure what aux input you're using - but be advised that if you've plugged your mp4 player directly into the RCAs in the back that won't work - those are outputs, not inputs.
You need to use a Pioneer CD-RB10 (or CD-RB20 if you're running a cd changer, XM tuner, or any other IP-bus component) in order to get an auxiliary input.
If you've done that - you need to go to the initial settings menu and set aux input to 'on'. Instructions are in this link, page 89.
Feb 27, 2008 | Pioneer AVH-5700DVD Car DVD Player
Aux input not working for mp3 player
Hi to you all. CAN YOU HELP ME? i have peugeot 206 and i have new kenwood CD MP3 and i also have aux input but I cant get any sound to come out at all?
Nov 04, 2007 | Alpine CDA-9883 CD Player
Eclipse CD2000 CD Player Logo
185 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
