Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hot point HVL-241 first edition 1400 washing machine
Our new machine fails to heat the water and after completing a cycle, it begins to take in water , do you need to remove the concrete anti vibration block ,mounted on the top of drum ?
thanks in advance
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Did you get this taken care of already?
    Yes, there are things that hold the drum steady while in transit and for transport and setup in the home. That being said, I can't address the concrete block you have. I suggest you ask at the place where you bought it. Otherwise, these other retainers are usually bright yellow, green or orange and if you don't remove these the machine will make a racket and walk around on its feet... no telling just what damage may result.
  • 1,294 Answers
Just leave that concrete block there, it is to prevent your tub from taking off skywards.
Posted on Jun 14, 2008
No water going into machine
Does it Hum or buzz when you begin the wash cycle? Just no water? is the supply valve turned on? Hot and cold both should be on.
if all you get is a humm or buzz and no water, you have a faulty valve that will need to be replaced so the machine can complete the wash cycle.
Dec 12, 2017 | Washing Machines
Washing machine will not complete spin cycle, but does complete the agiatation cycles
Have you thought of replacing it with a new front loader?
They save tremendously in water usage. Mine sames me at least $40.00 a month.
Jun 21, 2017 | Whirlpool Washing Machines
Washeing machine not heating up
It sounds like either the cable's have rusted off, fallen off the water heater element. Or the Water heater element has failed.
Watch this link to get the repairs done
How to replace washing machine element on Hotpoint washer
Mar 04, 2014 | Hotpoint Washing Machines
Manual zanussi essential 1400
You have a bad Drain Pump! It needs replacing. Unplug the machine first, Drain all the water out.
Jan 19, 2014 | Washing Machines
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
My dishwasher is installed, but it won't go past the "washing" cycle. I have very hot water and am not using the "sanitize" option. Any ideas what could be causing this?
Your Question:
"My dishwasher is installed, but it won\'t go past the "washing" cycle. I have very hot water and am not using the "sanitize" option. Any ideas what could be causing this? "
Hi, I have ideas about your dishwasher. It apparently has a failed timer.
If this is a new dishwasher installation of a new machine. Then it is defective and is covered under the manufacturer's warranty.
The hot water issue is fine. A dishwasher's internal water temperature should be at least 140 degrees, so the machine will heat up water to accomplish this.
I would cancel the cycle the machine is in test it in various cycles.
I would try it in sanitize as well. If it completes the full cycle. Then use it.
However, if it hangs up again. I will need a new timer mechanism.
Hope this helps. If you have any questions at all, reply to me through this website.
Best Regards,
Jan 22, 2011 | Frigidaire Professional Series 24 in....
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dish washer
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
May 14, 2008 | EuroTech EWF150 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
340 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
