Question about Bissell 8930M Upright Steam Cleaner
It wouldnt spray - Bissell 8930M Upright Steam Cleaner
It wont spray water but it willpick the water up
Posted on Mar 20, 2011
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
Not spraying water
I have sk460 spray mop and the 6 volt spray motor rusted up.
Looking for motor now.
Dec 09, 2015 | Vacuums
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Hoover floormate deluxe doesn't spray water
Fill tank with water.
Ensure the spray nozzle is not clogged from previous use. Refer to the manual for maintenance of the spray nozzle. Check YouTube for videos for this model. Contact Hoover website for support.
Aug 14, 2014 | Vacuums
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
At first my ipod wouldnt charge a few days after it wouldnt turn on. i have an ipod touch if that helps
First I would try a different charger for it, often the metal contacts inside the chargers can corrode just a little bit and prevent the electricity from charging your ipod and sometimes they just bend from general wear and tear. If the problem is not in the charger, then it is with your ipod itself. Unless you are familiar with opening and working on electronics yourself it would be easier to send it back to apple describing the problem and have them fix it. They usually have no problem with this (as they want to keep their customers faithful) unless the cause can be linked to product abuse.
Jun 06, 2011 | Vacuums
I have a bissell pro heat 2 it will spray water through hand held pipe system but wouldnt spray from main capet brush area can you help me please
Ours would not spray water either, after messing with it for ages I discovered the round black housing that the tank locks into where the water flows out of the tank was loose. So I held the housing from underneath while seating the tank & it started working. It's very flaky & a lousy design. Good luck.
Jan 16, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Powerwash proheat
If the unit is spraying ok but your just not getting hot water you could have a defective heater even if the light is on. To test you would need to take the handle apart and see if the heater gets hot by touching it give it about 2 Min's to heat up but be careful it will burn you if it is working properly. Another thing to remember is that even if it is working properly the water won't be very hot especially if you put cold water in it to start out with. The best thing to do is fill it with the hottest water you can get from the tap don't boil it or anything but this will help. If you need any parts or cleaning solution for this machine or any other visit www.stevessewandvac.com .
Jul 07, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 8930M Upright Steam Cleaner Logo
185 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
