Question about Bissell 1622 PowerLifter Upright Vacuum
I have a Bissell 1622 PowerLifter Powerbrush carpet cleaner and it will not dispense water/cleaner and it will not suction. I have tried just running hot hot water through it and it still won't work.
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell carpet cleaner
The spray hoses are bocked. The only way to clean them is to take the clear plastic cover off, un screw the base, lift cover, pull out red spray nosels, disconnect from main hose and wash under tap. Takes ages to do and is very fiddly.
Design fault as grit gets into spray holes.
Make sure you always clean machine after use,
Posted on Jul 26, 2008
SOURCE: 9200 Bissell carpet cleaner, water will NOT dispense
The water or soap line might be clogged, or something is broken. If it is just the upright part and not the handle, then its a solenoid, if its both then either the pump motor or the pump is not working.
Here is a list of parts.
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
Hope this helps.
Posted on Jan 08, 2009
My Bissell also STOPPED SPRAYING WATER.
I've owned a Bissell 9200 for a few months. I've used it twice, the last time most likely being around August. I attempted to use it this past weekend and it wouldn't spray. I searched all the help sites I could find and thought the solution was a clog in the heater, which many said was located in the arm. After I took the arm apart, to my surprise, THE HEATER IS NOT LOCATED IN THE ARM OF THE 9200 MODEL.
It's still under warranty, however am not located near a service center so I took it upon myself to try to fix it.
I'm just a single female who ends up trying to fix a lot of stuff herself so, I don't speak "technical instructions". But, here's what I did in the event that it may help someone else.
I unscrewed all the screws that I could on the base. I removed the cover over the motor. Doing so revealed the hoses attached to the soap dispenser. Located closer to the rollers were more hoses. On the same side as the foot lever, above the wheel is the where the HEATER is located.
Being that I was looking for a clog, I unclamped one hose at a time; inserted a safty pin into what the hose was attached to and wiggled it; re-clamped hose afterwards.
The only slight confusion may be with the screws. There are only two sizes. I used finger nail polish to mark where the small ones went.
I reassembled it, turned it on, and it actually started spraying again!!!!!!!!
So that this "blockage" won't occur again, I will take advice I've read about cleaning Bissell's hoses out after using it.
See, taking the thing apart was really nerve racking! Especially not knowing if it would even work after I put it back together.
GOOD LUCK WITH FIXING YOUR CLOG!....you'll probably need to sooner or later.
Posted on Feb 09, 2009
MNfisherman
  • 11896 Answers
SOURCE: will not dispense water how do I trouble shoot
Listen to see if you can hear pump run when pressing button, if the pump does run, than either you have a clogged nozzle or screen in water fill compartment.
Posted on Jun 22, 2009
Water will not dispense
check User Guide Page 11. There is a Lint Screen located on the tank lid. You should be cleaning this each time you use the unit, but many overlook this. If blocked a suction develops and fluid will not flow. If that didn't help try Page 15 for Troubleshooting.
Nov 14, 2015 | Bissell PowerLifter PowerBrush Upright...
Bissell proheat turbo 2x carpet cleaner
There should be 2 switches one for suction and one to disperse detergent.
Aug 15, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Grinding sound
You need to make a thorough inspection for debris and pet hair cloggin your vac. Could have ingested a load of kitty litter or....
Jan 20, 2013 | Bissell 1622 Powerlifter Powerbrush...
No instruction manual for bissel powerlifter carpet shampooer
go to this link:
http://www.bissell.com/customer-support/
there is a spot to put your model number in and you can download the owners manual. Good luck! Regards, Ross
Sep 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
It won't dispense water or suction it up
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
No suction. when i turn it on it cycles water intermittently.
you might need to replace the belts. The pump belt is what cycles the water. Here is a link to the belts you need and the manual:
Bissell Carpet Cleaner Belts and Manual
Dec 09, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Power wash /powerbrush sprays the carpet ok ,but when empty doesn't fill up with any dirty water from the carpet .Is there anything I am not doing correctly
It sounds like the suction isn't working right. Check the dirt tank to make sure it is on correct and check the red plastic filter on the dirt tank to make sure that it isn't clogged.
Dec 02, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Changing Belt
you have to unscrew the bottom of cleaner, there are instructions on bissell.com under removing a belt. Go to user guide
Jul 26, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 1622 PowerLifter Upright Vacuum Logo
159 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
