Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
The top freezer is working, but the bottom refrigerator is warm, around 58 degrees?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
What could cause the fresh food section of my refrigerator to be too warm?
UR COLD CONTROL THERMOSTAT, UR AIR FLOW VENT, UR THERMISTORS, A EVAPORATOR FAN NOT WORKING OR OBSTRUCTED
Feb 24, 2015 | Refrigerators
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer works fine, refrigerator only cools to 58 degrees on coolest setting!
replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 29, 2009 | Refrigerators
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
