Question about Chamberlain 3Button Remote Control Model 953 953CBH
Remote will open the garage door, but will not close it. It will move the door a few inches, and then return to the fully open spot. the control inside the garage works fine, except that recently you have to continually press the button for it to work.
    Scholar:
  • 143 Answers
This indicates that the safety sensors are mis aligned. You can re align them by hand. There should be an led light on each sensor and each should be on, not flickering or off, no matter the color. Also check the surface they are mounted to for stability. For instance if they are mounted to the track and the track moves as the door cycles then you will have issues. This should solve your problem. Thanks BB
Posted on Sep 03, 2010
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
My liftmaster will not close the garage door
Photo cells "safety beams" not aligned or bad, holding wall control will allow you to over ride them.
Jan 24, 2013 | Home Security
HOW TO RECONNECT INTELLICODE GARAGE DOOR CHAIN TO SAFETY CAM
please read carefully your owner manual, if you do not have a recommend to download from www.fitness.manualsonline.com or
www.manualsfactory.com
and proceed according with common sense
God bless you
Sep 09, 2012 | Genie Company IntelliCode GICT390-1BL...
My sears Craftsman 1/2 HP garage opener starts and quickly stops with a ****. sometimes only moving the door a inch or so. Lights on opener flash once, somethings power completely seems to go off... power...
Make sure all the connections are tight on the rear of the motor housing. The terminals where all those white wires go must be tight. Also make sure the plug into the wall is snug and not sloppy.
Jul 19, 2012 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin garage door opens to top limit bounces back to return down about 6 inches and then returns to open limit. What adjustments are neccessary?
The limit switch of both the sides are not reached. The drive must be realigned to work till the door closes fully so as to touch the limit swittch to switch off.
Similarily the open door must go to the extreme point to cut off with the activation of the limit switch.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
May 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not close door
safety beams are blocked or you have wall console in lock or vacation mode.
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 3Button Remote Control Model 953 953CBH Logo
135 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
