Question about Samsung NV24 HD Digital Camera
My Samsung nv24hd has been off for a long time because I missplaced the charger ihave now found it and have the camera on charge the orange light is on and has been for a few hours but there is no life at all coming from the camera
5 Suggested Answers
SOURCE: L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Posted on Dec 23, 2008
SOURCE: I have a Samsung P800
Ok. I have the samsung l200 but the cameras are very similar. I had the issue as well. When I plug it in it flashes red once, green once, then orange consistently. It would not charge the battery.
The fix was really quite unexpected. I did two things not sure which fixed it.
1. slide the cable into the camera slowly until the light turned red once, then pulled it gently in and out a few times.
2. as i plugged it in, I tried to angle the plug side to side sliding it to the left and right on a diagonal. I was hoping the pins would be touched differently when I did this which might reset something.
not sure which of these two things corrected the problem, but the camera is now charging.
Posted on Sep 14, 2010
zohail
  • 1223 Answers
SOURCE: light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
Posted on Mar 09, 2009
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
Posted on Jul 02, 2009
No battery light on charger on samsung st500
The rechargeable battery sounds like the main problem, but the charger needs to be checked to make sure there is not a secondary problem.
Jul 04, 2012 | Cameras
Hello Sir / Madam, I've got a Samsung Camera L730, 7.2 mega pixel, the problem is while charging, 1st it showed red LED light ( as usual ), then immediately an orange light starts blinking (as per...
Do you have change a Samsung L730 battery and to see if it can be charged? If you charge the battery in camera. It seems something wrong with the build-in charger core. If the camera all are OK beside charge battery, you can charge your Samsung L730 battery with a battery charger, and if your Li-ion battery is over discharged for a long time, it's bad for it. As your camera has been used for 2 years and it maybe not in warranty. To change build-in charger core should be expensive.
Apr 29, 2011 | Cameras
I bought an untested Samsung L730 digital camera without a battery, I have bought a USB charger/data cable but the orange flashing light on the charger stays on. I am using Windows XP. Is it likely that...
You CANNOT charge a camera through a USB port there just is not enough power! you need to get an original wall charger and power up from that. Even the USB cable/wall charger will NEVER charge it up sufficiently.
The USB cable is for data transfer only.
Aug 07, 2010 | Samsung Digimax L730 Digital Camera
My Samsung L73 digital camera will not charge. Batt is dead. When I plug the charger in, the camera led turns green, then orange, then off. No matter how long I leave the charger plugged in, it will not...
Have you recharged the battery many times since you owned it? Did you leave it alone for an extended time and it completely discharged and died? Rechargeable batteries sometimes only last 3 years.
Jun 14, 2010 | Samsung L73 Digital Camera
Samsung L313 Charging Problem
it sounds like the battery is faulty. try a new one.
Aug 28, 2009 | Cameras
Samsung nv3 camera not charging
Jun 29, 2009 | Samsung NV3 Digital Camera
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
NV24HD settings problem
go to menu-setup/settings-date time
then change it
Jan 05, 2009 | Samsung NV24 HD Digital Camera
Samsung NV24 HD Digital Camera Logo
302 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
