posted by jimmyred on May 09, 2008
the screen flickers even when the cpu is connected, but if there no cpu connected its always on then it will go off. i had to push the start button again to get it on. what do you think is the problematic part/s?
Solution #1
posted on May 09, 2008
check for bent pins on the sub-D connector. flex the monitor cable while its turned on.. a cut wire will yield just a flickr. especially the H and V sync lines.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sampo AlphaScan 521 Monitor
Email this problem
Email this problem
Can you Help with these Monitors problems?
Repair Service
Find Monitor Repairman Near You:
