Question about Toshiba SD-K740 DVD Player
I have a Toshiba DVD player SD K741. For the past few days, when I load the dvd, I receive a message on my TV screen "Incorrect Disc." What can I do to correct this?
  • Toshiba Master
  • 3,866 Answers
Incorrect disk error are common with the user putting in a disc that is not compatible with the player, in most cases it would have been a RW, that was written incorrectly. If this is not the case and it is a original disc you might want to purchase a cleaning dvd witch goes in and cleans the lens.
If that does not work then the unit's lens might be defective at this point.
1. Try other disc
2. try a cleaning disc
If those do not work then the issue is with the lens.
Thanks for your question please do not forget to leave a rating.
Posted on Aug 31, 2010
  • mlryan66 Apr 05, 2011
    My Toshiba TV/DVD player has the same problem. It is NOT because it's an incorrect disc -- they're all commercially produced discs that USED TO play just fine. If cleaning the lens doesn't work, what's next? What does it cost to repair/replace the lens?
    This unit is fairly new, and it was by no means cheap. Given the poor quality I'm experiencing, I'm reluctant to put a lot more money into this unit in repairs, but at the same time, it shouldn't be disposable.
    I bought it based on Toshiba's good reputation, and I'm terribly disappointed in the quality of it. I'm on the verge of cancelling my Toshiba laptop order because I'm afraid I'll just be buying more problems.
My toshiba sd-3205 will not load any of my DVDs anymore, the discs I insert into the player are in perfect condition and have loaded previously when the DVD player was working. it always says...
Probably dirty pick up lens.
Get a lens cleaning disc and run that and see if that cures problem.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba SD-3205 Multi-disc DVD Player
After I insert the disc, the digital readout say bAd and the screen states Incorrect Disc.
There is an recall from Toshiba for "bad" problem in Toshiba SD-3980 dvd player.
"Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit. If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit."
Click Toshiba Support link for original message, please contact Toshiba and above number for replacement unit.
Hope these info will help you.
Thanks.
Feb 12, 2011 | Toshiba SD-3980 DVD Player
Toshiba 4100 single dvd player won't load. Screen displays loading message but will not. Any suggestions?
Please clean the lens then retry to load the disc. Replace the lens if still fail to work
Jan 10, 2011 | Toshiba SD-1700 DVD Player
Our sd-k741 player is playing previews but not the actual movie itself. Once the previews are finished, we get to the main menu and then we hit "play movie" and we get an circle with a slash through it and...
www.tacp.toshiba.com/tacpassets.../sd-k741/docs/sd-k741_om_e.pdf
If it does this with Any/Every movie no matter what, then your "Brain" in your unit, has gone faulty, and is freezing at the Load the Movie loading instructions, perhaps bad RAM, or a HDD problem whatever, you will have to get it serviced.
Jun 01, 2010 | Toshiba SD-K741 DVD Player
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Incorrect Disc
We removed the top disc by placing black electrical tape onto the top of the disc and gently pulling it out.
Mar 26, 2008 | Toshiba SD-V392 DVD Player/VCR
Toshiba SD-3890 several related problems, I think!
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
Check this page, there is a problem with one of the components that causes it to fail. Call the number to get a replacement.
Jan 26, 2008 | Toshiba SD-3990 DVD Player
DVD player - ERR
error in any disk i put in!!!!!!!!!
Nov 14, 2007 | Toshiba SD-V280 DVD Player/VCR
Device display now says "bad" and TV display says "Incorrect disc"
Sounds like the player has a dvd mech/picup problem, will probably require a repair that is more expensive than a new player, they are as low as $30 and personally I dont even try to repair my own, I just go buy a new one. There may have been some dirt on the disc that is blocking the laser if you want to try a cleaning disc I doubt it would hurt it anymore.
Jul 07, 2007 | Toshiba SD-K741 DVD Player
Toshiba SD-K740 DVD Player Logo
995 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
