Question about JVC AV-27020 TV
JVC TV MODEL AV-27020 red light blinking on front of tv and it will not work.
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: blinking timer red light on jvc tv, no other functions
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
thedayos
  • 57 Answers
SOURCE: RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Posted on Feb 28, 2009
ginko
  • 19396 Answers
SOURCE: TV turned off itself and timer light (red) keeps blinking
romsky79
  • 822 Answers
SOURCE: When I turn the TV power on, the TV picture won't display, but the timer display (red blinking light) blinks momentarily and then clicks off. What is the problem and how much would it cost to have rep
check the horinzontal out transistors. call qualified personnel to fix.
Posted on May 30, 2009
I have a GE remote and an I'Art JVC tv, cannot get remote to work.
Setup codes for JVC with GE remote control are:
0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Jul 29, 2012 | JVC AV-27020 TV
JVC PROJECTOR TV 61INCH
try to checked the memory program I.C. located near the controler I.C. or it maybe put you on timer mode, try to go menu and checked the settings
Jul 30, 2009 | JVC AV-27020 TV
Blinking Timer Button
The tv must of turned on the timer by itself. They do do that sometimes. I suggest leaving it unplugged for 24 hours to reset itself.
If problem persists, you may be able to go to your menu and access the sleep mode timer and set it to 0:00 or OFF
Jul 10, 2009 | JVC AV-27020 TV
Tv won't turn on
You can try checkin the fuses I had a problem like that with my stereo receiver took it apart changed the fuses works great
May 06, 2009 | JVC AV-27530 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
Digital Tuner or Analog
I have the JVC AV-27020 and had to download the manual just today. I checked where I got my manual and they did not have anything for an ACV-27020. The link for the TV manual I downloaded is below. Maybe it will help.
http://www.retrevo.com/s/JVC-AV-27020-TVs-review-manual/id/279ag501/t/1-2/
Aug 10, 2008 | JVC AV-27020 TV
JVC AV-27020 TV Blinking LED, Static Electricity on tube but no sound and image
Sounds like a bad main regulator IC.. Try putting a 100 watt light bulb across the main AC fuse, turn on the set and see if it will stay on longer. If it does, replace the main regulator iC. If it does not, then it could be almost anything in the sweep section of the set, and or in the regulation circuit of the power supply. Look for slightly swollen capacitors in the set. good Luck please do not forget to rate this thread.
Dec 10, 2006 | JVC AV-27020 TV
JVC AV-27020 TV Logo
151 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
