Question about Dell 926 All-In-One InkJet Printer
Printing Alignment The printer display states printing alignment. a And will not let me print. Any Solution
  • rburger Jul 21, 2008
    I put in a new dell color cartridge, the printer alignment mode comes up, it prints out a copy of different colors and then when its done it tells me theres a problem with the alignment and there is tape on the printer head. I have cleaned it off and wiped it clean, and then it prints another test page for the alignment, and again it tells me there is a alignment problem and tape on the cartridge.After several test pages I'm still having the same problem and half of my printer cartridge ink is gone.
  • royce09 Apr 05, 2009
    I have the dell 926 and the message paper alignment keeps coming up. I can't print anything from the computer.
What can I do if my printing is only printing alignment
Posted on Nov 27, 2008
Mine was doing that and I just made a copy of nothing (my hand actually) and then reprinted the document and it worked fine! Sounds weird I know but it worked! lemme know if works for you
Posted on Oct 27, 2008
I just called dell and they told me this:
it could be that you have a high capacity printer and you bought a standard ink cartige. So you might want to look at the box it came in and see if it says standard. Good luck :)
Posted on Oct 23, 2008
    Novelist:
  • 144 Answers
Hello!
It may be one of the cartridges is defective. Try replacing the cartridges to see if the problem clears or the printer just need a little clean up. you may also try this
Step 1: turn printer off.
Step 2: unplug power brick.
Step 3: MANUALLY move cartridge carriers towards the center.
Step 4: take cartridges out.
Step 5: move carriers to the RIGHT.
Step 6: CLEAN the shiny silver bar that is connected to the carriers using a dry cloth, from left to right in one direction.
Step 7: move carriers to the LEFT.
Step 8: CLEAN the shiny silver bar that is connected to the carriers using a dry cloth, from left to right in one direction.
Step 9: move carriers to the RIGHT.
Step 10: CLEAN the see-thru tape that is connected to the carriers using a dry cloth, from left to right in one direction. (careful, it is delicate, clean both sides).
Step 11: move carriers to the LEFT.
Step 12: CLEAN the see-thru tape that is connected to the carriers using a dry cloth, from left to right in one direction. (careful, it is delicate, clean both sides).
Step 13: put power brick back in. turn printer on.
Step 14: put inks in.
Step 15: press check to print alignment page.
If the problem persists, possible that the printer is defective
Posted on May 09, 2008
Slow printing
Remove both cartridges, switch off printer and then on. After cartridge holder comes to the center install both the cartridges. Then it will print the Alignment page. After alignment page prints place the Alignment page on to the scanner and press SCAN button as mentioned in the Alignment page. After completing the scan try printing. It will print the usual speed.
Note: For the alignment process both cartridges should in good working state
Jan 24, 2013 | HP DeskJet F380 All-In-One Printer
New cartidge now printing light. Also message states cartridge alignment fails. Please help. Thanks, John
What you could try is to do a Clean the Print Cartridges operation. This process will clean the cartridge printhead and will print a better alignment page.
Jun 26, 2011 | HP Photosmart C4180 All-In-One InkJet...
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Apr 19, 2011 | HP Office Equipment & Supplies
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have a 5610 all in one printer and when I just put in the new cartiges it gives me an error message stating "Cartige not aligned".
Issue
The instructions displayed on the computer screen during the Print Cartridge Alignment are incorrect. If the printed alignment page is placed on the scanner glass and the Scan button is pressed as instructed on the computer screen, the all-in-one will beep and the control panel display will indicate Busy . The all-in-one will not align the print cartridges.
Workaround
The instructions on the printed alignment page or the all-in-one control panel display are correct. Follow the instructions below: Place the alignment page on the scanner glass and then press the OK button on the all-in-one to complete the print cartridge alignment.
Mar 04, 2011 | HP Officejet 5610 All-In-One InkJet...
HP 2210 New Black Ink Cartridge print alignment page over & over.
unplug the printer while it is in ON state..it will reset all settings..^_^
May 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Nov 10, 2008 | HP Photosmart 2710 All-In-One InkJet...
Aligning Print Head Alignment
Press ENTER.
Oct 04, 2008 | Canon BubbleJet i550 InkJet Printer
Canon pixma mp780
Press ENTER.
Jul 11, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Dell 926 All-In-One InkJet Printer Logo
401 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
