Question about Acer Aspire One Netbook 8.9" Notebook
I bought a new accer laptop. after fixing the battery i powered the machine only to fine learner and parent as a user. i wanted to user the parent user but it has benn password
  • Acer Master
  • 11,800 Answers
In that case you should reinstall Windows and set your own passwords.
Posted on Aug 31, 2010
Parent Password...?
Since it is your private laptop, why not reset windows password and to create a new windows password or without password, so that you can do anything you want in your computer.
And how to do, three ways:
Way1: use safe mode
Way2: use reset disk
Way3:adopt windows password reset
Details: Windows Password Reset Article
May 16, 2012 | Samsung R Computers & Internet
My laptop acer 5101awlmi wont charge my battery i have bought a new battery and charger the new battery worked fine until the power ran out. i can only use it now when it is pluged into the mains charger...
take it to be fixed my laptop did the same thing but i had vista at time
it is something internaly so you will need to take it in to a repair shop
Feb 07, 2011 | Computers & Internet
Laptop dead
Being a lap top, remove the battery. You should be able to rum direct power. If you still can't start it, you have a bad capacitor or zenor diode on the motherboard and I would lean to the capacitors. If it's not the battery it isn't something most users can fix. It takes a hot air workstation and special tools to remove solder so you don't damage the board. A service center might be able to do the repair but most likely they will want to replace the motherboard if that is the fault and after paying for that you might as well have bought a new machine.
Jul 01, 2010 | Computers & Internet
Unable to get parental controls to work in Windows Vista Ultimate
Hi, Well windows has 1st launched this service with vista..on per user basis. It was not mentioned by you do u want a solution while logged in as administrator or user. I have given answers for both of them. As per your requirement you can select. For Administrator In d 1st case make sure that you r logged in as the administrator, while following these steps:
  1. Click on start button
  2. Go to control pannel, n select parental control.
  3. A User Account Control prompt will appear asking if you would like to continue. Click on the Continue button to proceed with opening the Parental Control
The screen which opens is the control panel.From here you can apply parental controls for the whole system or even for the standard users. For creating a new acc
  • Click on the create a new user tab
  • In this screen you would type the login name for the new user account that you would like to create. We also suggest that you leave the option labeled User must set password at next logon checked so that when the user logs on for the first time they will be prompted for a new password enabling them to keep their password private.
  • When you are ready to create the user, you would click on the Create Account button to finish the creation process. You would then be brought to the Parental Controls page for that particular user. J
Just press the OK button to get back to the welcome screen. Now from here you can keep the parental control setting as per your requirement on the following Global game rating systems setting, Family Safety Options, Activity Report Reminder, Web Restrictions Page etc
Now if you are a user/ domain and want to put up parental settings follow these steps;
  • Open the Run dialog box.
  • Type gpedit.msc and click OK
  • When the UAC prompt appears, select Continue.
  • The Group Policy Object Editor window will appear.
  • Under Local Computer Policy, expand Computer Configuration.
  • Expand Administrative Templates.
  • Expand Windows Components.
  • Select Parental Controls.
  • In the right pane, right-click Make Parental Controls control panel visible on a Domain.
  • Select Properties.
  • Select the Enabled radio button and click OK
  • Close the Group Policy Object Editor.
  • Resart the machine, for changes to take effect.
Nov 25, 2009 | Microsoft Windows Vista Ultimate Edition
New battery for toshiba laptpo 4600 but stillnot holding charge
Two options, though check your user manual (if you have one...):
1) Many modern laptops work fine on mains power without the battery installed. So try removing the battery and switching on just with mains power. And when you switch on, press the on/off switch hard.
2) Many laptops have a reset switch. Sometimes this is somewhere around the keyboard (you may need a needle - the blunt end!! - or similar to press it) or possibly under one of the removable covers on the underside.
Jun 24, 2009 | Toshiba Satellite Pro 4600 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Forgotten parental control password
that easy to fix go to your control panel click on users click on your user profile and u can change password in there if for some reason it wont let you create new profile and set that as admin.and delete other profile and click on save all files and it will fix this problem
Mar 26, 2009 | HP Pavilion dv9000z Notebook
Notebooks
Well it surely shows that the battery is not providing backup to the laptop. There could be two reasons for the same
1. The battery is not compatiable.
2. Defective and faulty battery.
However i will give you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it is charging the battery and provides you the backup.
Please let me know what happens.
Regards
Sammy
Jul 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
