Question about Garden
I had to replace idler pulley on a jihn deere 212, cant remember how to route belt
  • 490 Answers
Howdy, this diagram was originally found for another customer by wireguy (other guru here at fixYa.com). It is for the JD 212
I had to replace idler - 9b184ed.jpg hope that sets you up. there is a lot of info about maintenence,etc. at Johndeere.com
Happy mowing:)
Regards,
farmerbear
Posted on Aug 31, 2010
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
Pictures of the engine
Your wish is my command:
Apr 09, 2014 | 1997 Buick Riviera
Maytag lde 212 dryer, drum not turning, new belt I think it is routed correctly but seems loose, can you tighten spring tension on the idler pulley?
hi easyrb...
If your belt is new and it is loose, then you have routed your belt wrong.
Follow this link and you will see the correct way to route your belt
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 11, 2011 | Maytag Dryers
I need a manual to show how to put on a belt on a john deer #68 mower
I don't have a diagram but it shouldn't be to hard. You will have to drop the deck. Then when installing the new belt remember to always place the inside of the belt (V) into the pulleys and the outside of the belt (flat side) up against the larger idler pulley. When you have the belt on properly it should be snug. If you have excessive play you need to try a different routing2.gif around the idler.
Good luck and let me know if this helps.
Thanks
roundo4
Sep 06, 2009 | Briggs & Stratton Garden
I need a drive belt diagram for a 1974 john deere garden tractor 112 wiyh 12 hp kohler engine
I don't have a diagram but it shouldn't be to hard. You will have to drop the deck. Then when installing the new belt remember to always place the inside of the belt (V) into the pulleys and the outside of the belt (flat side) up against the larger idler pulley. When you have the belt on properly it should be snug. If you have excessive play you need to try a different routing around the idler.
Thanks
roundo4
Sep 06, 2009 | Garden
I have a john deere sabre 15.5/42 and cant figure out how to put the deck belt back on
Remember to always put the V side of belt (inside of belt) into the pulleys and put the flat side of belt (outside of belt) up against the idler pulley (the one that moves to make belt tight to engage blades) Make sure you have the right belt and follow those guidelines and the belt should go right on. If you happen to have alot of slack then you have to figure out a different routing around the idler. Make sure the blades are NOT engaged. When on properly the belt will be snug.
Let me know if this helps.
roundo4
Aug 28, 2009 | Garden
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Jun 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Garden Logo
159 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
