Question about Poulan Garden
.trying to get a reassambley diaigram for carb
    President:
  • Poulan Master
  • 1,545 Answers
Find out what model carb it is...eg...C1U...C1Q...and look at one here: http://www.m-and-d.com/zama_carburetor.html
Posted on Aug 31, 2010
Weedeater featherlite high altitude carb kit
There are not different jets for the carburetor, the only thing you can do is to adjust and run high octane fuel.
Sep 15, 2017 | Weedeater Garden
Leaf blower wont run
Make sure the muffler isn't plugged with carbon. If it is you can use a hand held torch to burn out the excess carbon.
Aug 17, 2012 | Weedeater Garden
I have an antique stihl weedeater that will not stay running I've cleaned the carb.,the carb sceens and replaced the primer bulb I'm not 100% sure about the scew settings.
You probably know that it may need a rebuild kit with the new gaskets and diaphragms in it. It is quite possible a kit exists for it even though it is antique. Is it a Walbro or a Zama? I will send you to a tutorial by Zama on tuning a 2 stroke carb which includes your mixture screw settings. If you need help finding a rebuild kit or just a gasket w/diaphragms kit, please post back. I will be glad to assist.
http://www.zamacarb.com/tipspage.html
May 07, 2011 | Garden
Need "L" and "H" setting on carb mixture screws
Lightly seat the screws all the way in....then back them out about 1 and 1/2 turns. From there here is how to do the final Zama diaghragm carburetor adjustments.
Oct 30, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
My weedeater lawn edger wont start. I get no gas in the primer bulb, but has fuel in both the main line and the return line. I blew out the fuel fliter and both lines but still no fuel in the primer...
There may be a malfunction in the check valves in the primer base assembly. Before attempting to get a new assembly, take the retaining screws at the bulb off, remove the bulb and spray the assembly liberally with WD-40 or an equivalent light lubricant. Sometimes this will free the check valves as they only let fuel flow one way and there are 2 of them in the primer base.
Do not use strong solvents, do not ever soak, and never use high PSI compressed air on these carbs. Sometimes, when the check valves in the primer base go bad, the carb floods and the reason is unclear. Zama doesn't list this as a reason for their carbs flooding, but they can. You may wish to view a parts breakdown list for your specific carb. You will need to know the type (stamped in side of carb body) and the model (stenciled in side of carb body). It will be something like a C1U type and a W-18A mode...thus its a C1U-W18A Zama carb. Here is a link to get you started.
http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
Yours will be listed under Poulan/Weedeater
Aug 22, 2010 | Garden
How do i repair a choke lever in a weedeater te475y gas trimmer? Does the lever pull straight out of the carburetor.
Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
Here is a parts breakdown for your machine:
http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
Jul 09, 2010 | Husqvarna Garden
Sears featherlite weedeater wont start
Needs carb rebuild kit and carb rebuild,likely its one of those carbs made in china.
Jun 06, 2009 | Homelite Mighty Lite Lawn Trimmer
Weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
May 26, 2009 | Garden
My featherlite weedeater will only turn up on half choke?
you have to adjust the h or highend carb screw. start up your engine on full choke adjust the screw up or down untill u can run it without choke
Apr 21, 2009 | Garden
Garden Logo
532 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
