Question about Canon PIXMA MP240 All-In-One InkJet Printer
Hi...my canon Pixma MP240 hasnt been working for awhile. It just stopped printing, and as far as i know it wasnt an error that I caused such as something broke off or spilled in it...I have tried everything that i know of to fix it. Presently, the alarm is flashing orange, 2 times consecutively, as in 1,2 skip 1,2 skip. On the screen it is flashing P and then 2. I am grateful for any feedback! Thank you so much!
  • jarensmommie Aug 31, 2010
    Hi...thank you for your advice. I did exactly what you instructed, and was hopeful it was going to work. It definately needed cleaned and i put everything back in after cleaned, shook it gently, and blew air through it. I tried again to print something and it now says service error 5100 on the computer screen and the same thing before on the printer screen...The best way i can describe what happens is i press print, and the machine loads up, moves back and forth, but when its time for the spool to pull the paper down to start printing, it never does it. Then the error messages come on...so, i appreciate the advice on cleaning the ink sponges etc. but it didnt fix my problem. Any other suggestions? Thank you for your time!
  • 2,973 Answers
It could be a driver fault as well. So, before doing anything to the hardware, please un and reinstall the drivers for your device. Follow the link below for this purpose. And remember that reboots are as important as any other procedure.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Sep 01, 2010
  • Canon Master
  • 4,737 Answers
I can't make it specific what exactly the error indicates. There seems to be two error, 1. Flashing orange and 2. error P2. The orange flashing means the ink pads (waste ink tank) is full. Sometimes this error is just showing when there's some minor problems like improper shutdown, etc...but in fact there are two ink pads where the cartridges (with the carriage) reside when they are not printing. You will be able to see these pads after the carriage is moved aside towards the center. Lift up the scanning as you are replacing the cartridges, and look at the compartment where the cartridges were, you'll see sponges soaked with ink/s. Catch a tweezer, pull them out and clean them with water, squeeze them and leave them to dry. After it's done, clean the compartment properly. If you can't reach it, hold a cloth with the tweezer (you'll need a long tweezer) and try cleaning or place it so that the the ink will be sucked out from the pads/sponges.
I think i've skipped one step, you have to remove both the cartridges and the printer should be turned off by un-plugging the power cable before you follow the instructions mentioned above.
After everything's cleaned and you have done whatever is possible with it, check all the passage of the machine. If possible, use a blower to cast out all the dusts clogged/stuck inside the compartment. Or it's possible that there're pieces of paper broken and stuck during a paper jam. Lift up the printer and give it a good shake. (sounds funny, but even lifting and shaking can fix the most annoying issue).
Now install the ink pads/sponges (if you've removed them), install the cartridges, and press the power button (hold down) while you plug in the power cord. After it's plugged in, release the press and again press once to power on. This will definitely fix your problem if there's no other internal issue with the machine.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 31, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 01, 2010
    Well, there's another error have come up. This service error 5100 indicates that the machine is having a carriage problem. First, clean the timing strip, (the plastic strip/band that carries the carriage and cartridges). After it's properly cleaned, do the following:
    Are you sure that the cartridges are still working? This is another question, but cartridge issue also causes this problem.
    You are right, fixing the problem takes time. Since this error is related to several issues, we can't fix it in one hit
    After the cartridges are replaced with the same problem, then follow the below instructions, step by step, in the order/sequence stated below:
    • Turn off printer
    • Hold down "Resume" button and press "Power" button to power on the printer.
    • Now hold down the "Power" button and release the "Resume" button.
    • Again, press "Resume" button twice then release both the buttons
    • You'll see green lights flashing and then it'll stop blinking and will remain static.
    • At the time when green lights remain solid, press the "Resume" button (four) 4 times.
    • Again, press the "Power" button and the printer should turn off, if it's still On, once again press the "Power" button.
    Now see if this helps or not..
    Good luck.
    Once again, thanks for using FixYa.
  • Naeem Dec 19, 2011
    Just use a soft dry tissue and clean the thin transparent strip along the printer carraige gently and make sure that it is transparent all along the strip. You have to open the printer from the front to do this and to get to where the printer head stands turn it on and the head will park in the middle so that you can clean the right side of the strip. Then all should work as is, it worked for me
Printer not responding?
Try removing the printer and re installing it. Sometimes computer updates can cause errors.
Jun 12, 2012 | Canon PIXMA MP240 All-In-One InkJet...
Canon MP240 printer, error code P8. Can't print, can't clear error code
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
for more help visit CBR Tech Solutions
Mar 15, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I keep getting a "Error
You can download the manual for the MP240 printer here:
http://files.canon-europe.com/files/soft33024/manual/MP240%20series%20On-screen%20Manual%20(EN).pdf
According to the manual, and some forums I have read, the 5100 error is caused by a problem with the print head / cartridge assembly not being able to move correctly.
Can you check if the print head / fine cartridges are seated correctly and nothing is obstructing them or causing a jam.
Can the print head / cartridge assembly move smoothly side to side along its track.
Can you check the inside of the printer for any foreign objects that might have fallen in and are causing a jam?
Some of the solutions I have found suggest using a drop of oil on the track that the print head moves along (a light machine oil such as 3-in-1). Be very careful and only use 1 small drop as a little goes a long way.
Please let me know if this helps and if not I will keep looking for you.
Many thanks,
Chris
Mar 09, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Change ink cartridge in canon pixma mp240?
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-MP240-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Feb 25, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Ive had the ink cartridges refilled on my canon pixma mp240 and i need to override the 'empty ink' warning. its not printing the correct colours and driving me nuts!
Yes you can override this empty error, when the printer is on, press and hold stop/reset for 5 seconds until the empty lights go out.
Nov 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Service error 5200 canon mp240
Sir,
Error 5200 indicated an error with the print head. Try to cleaning all contacts on the print head as well as on the connecting pad. And also the power needs to be restated, so do it and try it again, just take out the USB, the power from the wall outlet and the USB in the printer itself.
Thanks Good Luck
Sep 17, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Will the canon pixma mp240 continue to print
you need to have both cartridges somewhat full to run, there is a initialization routine that the printer goes thru and if you don't have good cartridges with ink it won't let you print.
Aug 16, 2009 | Canon Office Equipment & Supplies
Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
Jul 22, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
142 people viewed this question
old marine
old marine
