I have a york high efficiency furnace, which i believe has a gas modulator and variable speed blower. When the furnace ramps up the blower to a certain rpm i hear a howling noise which is loud to the point where it wakes us up at night when it happens. The furnace runs great & quiet 90% of the time but makes this irritating noise for some reason every once in the while.
  • Heating & Co... Master
  • 3,315 Answers
Try oiling the fan motor
Posted on Sep 01, 2010
Furnace. Cycles on and off And onduring heat
If it is a newer high efficient furnace, some have what are called 2 stage burners and variable fan speed motors which will do this as to be efficient. If it is still very bothersom to you, have a qualified HVAC person look at it.
press the helpful button, check link below
Single Stage vs Two Stage Gas Burners
Jan 10, 2016 | Heating & Cooling
Tip
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of cranking up to the highest heating output in mild weather you can be more comfortable while saving money.
Many people think that they are getting the best they can get by buying a high efficiency single stage furnace. What they often don’t realize is that they could do better yet and for a few dollars more have a high efficiency 2 stage furnace that could keep them much more comfortable.
There are 2 stage hot air furnaces that are now available that will only run at half fire if the full fire is not needed. With a two stage furnace in mild weather when only a little bit of heat is needed, the furnace will have longer run times on low fire. This will keep you room temperatures from getting too hot before the thermostat reacts and shuts the furnace off again. This will help to keep your temperatures from overshooting the set point and help to keep your home much more comfortable.
Many of these two stage furnaces also have variable speed blowers that run at a lower speed when heating on low fire. This will also help to save money on your electric bill, because these blowers use very little electric when running at these low speeds. Air noise from the blower running at a high speed is also reduced.
If you are thinking of replacing or installing a hot air furnace, make sure that you ask your contractor to give you a price on installing a two stage furnace. The price difference probably will not be much higher than a high efficiency single stage furnace. However the comfort of the two stage furnace coupled with the electric savings will make the extra money well worth it.
on Dec 14, 2009 | Heating & Cooling
Is there a high effecency furnace substitute?
small dual gas turbine and use electric heating and supplies your home also ....
Apr 19, 2015 | York Furnace Draft Inducer Blower Fasco #...
Gas central heater
The "mother board" or integrated control module is essentially the brain that controls the sequence of operation in your gas fired furnace. It is located, generally, in the blower compartment. That is the bottom of the two compartments of the in the furnace. It looks like a circuit board with all the wires of the furnace leading to it.
Feb 28, 2014 | York Furnace Draft Inducer Blower Fasco #...
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
Just replaced inducer motor, runs great but furnace will not ignite
Check the pressure switch and the little hoses going to the pressure switch. If the pressure switch does not get a vacum from the blower it will not let the furnace light.
Heatman101
Mar 03, 2010 | York Furnace Draft Inducer Blower Fasco #...
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
Fan only runs on high - variable speed goodman gmh0950703bx furnace tried moving wires around to no availe, gas on low flame and still only high fan - help
your variable speed modulator on the fam motor it self has gone bad.
it can be easily removed and unpluged, and repaired by you
i believe goodmans are held on by 3 scres around the hub and a four wire connector back to the control
with out the exact modle of the fan i cannot help you find the modulator
but almost any HVAC supply store in your area will have it on the shelf....very common part
or they may need to order it
but its probably cheaper online somewhere
when you get the model of the var sp cntrl
type it in google
im sure it will pop up in a few hundred hits
Oct 25, 2009 | Heating & Cooling
Condensation from small blower shorts out circuit board.
Put a plastic bag over the control board that will allow it to breath. you can add sealant to joint but you should clean the old off first. Then use some cork tape after sealant dries. You may also use pvc glue but it will never come out after that, but can be cut w/ saw if that becomes nessary.
Feb 01, 2009 | York Yankees Bedding MLB Comforter
Heating & Cooling Logo
335 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
