Question about Janome Memory Craft 10000
MY lock 204D tension problem.
I'm trying to use Janome my lock 204D and the tension is all wrong, I lost the manual and need help.
  • evs2 Oct 11, 2008
    my thread on the bottom right hand dial keeps breaking ,
    have thread it , as diagram ,
    even put thtread through tiny hole on top of arm, and then through needle ,but where should thread go to back of machine, in front of other needle , or what?
    thanks
  • Janome Master
  • 1,388 Answers
Check all the tension units are clean and clear of lint
Ensure sharp new needle/s,
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, and that you have threaded through all the guides.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
Now set up machine with 4 different colours, so you can easily see any changes you make.
Factory setting for all 4 tensions = 3.........try this setting first before altering anything.
Sew a test sample about 75mm (3") and look at the result, front and rear.
You will see anything tight or loose, so just adjust a little at a time with test samples each time.
If the actual knobs read anything other than the 3-3-3-3, after you have made your adjustments and are happy with the balance of tensions, it is quite simple to remove the knob....very gently pull it off towards you (without altering the new found correct tension !!) and pop it back on to read 3.
Hope this is all easy to follow, If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on May 09, 2008
How do i sussecfully thread my janome 204D overlocker machine
The detail for threading could not be more clear...there is a diagram on the inside door...ensure thread is pulled tight in tension units.
Nov 11, 2011 | Janome MyLock 204D Mechanical Sewing...
Lost manual janome overlocker 204D
You can purchase the manual and other parts for this machine at http://www.sewingpartsonline.com/janome-204d-parts.aspx.
Jun 27, 2011 | Janome MyLock 204D Mechanical Sewing...
Please help me find a manual for a janome mylock 234
Hi
I couldn't find a manual for the MyLock 234 on the Janome site.
There is one available free to download for the MyLock 204D.
http://content.janome.com/documents/File/ManualFile/MyLock204D.pdf
I think it's only a partial mauanl but it should be similar enough to help you get atrted witht the basics of threading the machine etc.
Hope this helps!
Nov 08, 2010 | Janome MyLock 644D
Hi, I have acquired a used Janome serger, My Lock 234D, but it came without a manual. I'm wondering where I can download one, thanks!
Hi
I think it's only a partial manual but it should be similar enough to help you get started with the basics of threading the machine etc.
Hope this helps
Nov 07, 2010 | Janome MyLock 634D Mechanical Sewing...
Have lost my manual for mylock 204d, want another one.
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 10, 2010 | Janome MyLock 204D Mechanical Sewing...
Janome 4014 manual
I,m looking for a manual for a janome MyLock 204D serger could you tell me where or how you got yours please. email prbertrand@live.ca
Nov 15, 2008 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
260 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
