Question about Amana Dryers
My Amana electric dryer sometimes will not heat and timer will not move. The dryer will just run and run. If I unplug the dryer for a few hours it will work again, but the problem will return.
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
  • dupont_richa Nov 29, 2010
    I have replaced the timing unit and The timer still does not move.
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Timer wont advance runs non stop will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Amana NED5200TQ Electric Dryer
Amana 7200 dryer, runs but has no while running.
heatman101
Dec 31, 2010 | Amana NED7200TW Electric Dryer
Amana dryer, no heat, drum turns, timer not advancing
heatman101
Dec 13, 2010 | Amana DLE330RAW Electric Dryer
Dryer Tunrs on and runs with no heat and timer never moves
heatman101
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
63942 Dryer: runs air no heat , timer does not move...
heatman101
May 18, 2010 | Kenmore 63942 Dryer
Dryer runs, but does not heat and timer does not move
heatman101
May 17, 2010 | Hotpoint NVLR333EE Dryer
New Dryer and there is no heat and the timer is not moving !
you need to first check your power do you have 240 nstraight across your receptical? i would flip breaker on and off. see what happens...what was wrong with your other dryer?
May 04, 2010 | Roper REX4634KQ Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Whirpool amana dryer runs but no heat. on timed try timer doesnt move either.
HI, the timer motor is malfunctioning. this can affect the way you dryer heats in this case. I would advise to check the thermal fuse before replacing the timer. it is located on the blower house or, on the vent duct. in will show no continuity if defective. replace the timer if the thermal fuse is showing good continuity when measure with a meter.
Jul 24, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
91 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
