FixYa.com
Tags:
Intel D101GGC Motherboard
Problem with intel d101ggc motherboard
posted by Rohit R on May 09, 2008
i have a problem with my cpu fan when ever i try to play nfs carbon it starts well and after sometime the fan runs on full speed and gets restarted.i cleaned the the cpu fan several times i heard from a friend about speedfan the remote temperature is always around 70-80'C so how can i identify what is the fault.pls help me.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 10, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 88%, 1056 votes
Hi Rohit, you're CPU should not be running that hot & that is why you're system is restarting. Very soon the CPU will burn up.
Replace the CPU's HeatSink & fan assembly as soon as possible. The link I have posted is a list of the CPU's you're board can support.
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-025906.htm
Even at 70'c, that's too hot also. You're game is not putting that kind of load on you're CPU.
Comment by map9966, posted on May 10, 2008
Minimal requirements to run the game NFS Carbon,
CPU Speed (Recommended): 933MHz,
memory size: 256MB & OS, Windows 98, Windows XP, Windows Me, Windows 2000.
Below is a link for some Intel 775 CPU heatsink's & fan combo's.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1588
Good Luck!
Have more questions? Please feel free to ask.
Mike
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
motherboard
i have compaq presario sr1620ol... Answer This...
Motherboards
HI I need driver
mother board: Lite-On NR146... Answer This...
Intel D101GGC Motherboard...
first of all i say hi and the... Answer This...
Multimedia Audio
sound scatchy when paly music...
Hi all, I have a Intel101GGC... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
