Question about Kenmore Dryers
My kenmore 90 series dryer takes two hours to dry a medium load. it gets warm but not very hot.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
I. Have a kenmore 90 series dryer and it takes hours to dry clothes. What could be the problem
Check and make sure the dryer vent hose is not clogged with lint.
Nov 10, 2016 | Kenmore Dryers
Kenmore 120V portable dryer only gets lukewarm
Sometimes the venting in the dryer needs ton be cleaned out as it plugs up and the high limit thermostat makes it short cycle on the heat cycle.
Mar 20, 2010 | Kenmore 82722 Electric Portable Dryer
Kenmore 80 Series
90 percent of the time its related to urvent. remove the vent and run a load and see the difference
Feb 11, 2010 | Kenmore Dryers
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
Jan 28, 2010 | Kenmore Dryers
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
Kenmore 90 series dryer leaves clothes damp. The dryer gets hot, but after almost 2 hours a large load is still damp. Happens on both auto sensing & timed dry. Checked insides & all is clear -...
Sounds like a venting problem at the house pipe.
Make sure the house venting pipe is completely clean and vent hood just outside is free of any blockages.
If all that is cleaned I would check all working thermostats and high limit thermostat as well.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Kenmore dryer 90 series, heats a little, but doesn't get hot and takes 3 to 4 1/2 hrs to dry a med. size load.
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Jul 18, 2009 | Dryers
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
117 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
