Question about JVC AM FM CD DET FACE CAR STEREO
My JVC car stereo will reset to factory settings after 5 minutes of the ignition being turned off. what can i do to fix this problem?
  • JVC Master
  • 17,129 Answers
The power connection to the car stereo has two positive connections out of which one is connected directly to the main power -CONTINUOUS always ON , and the other is connected through the switch.
In your case I think both the lines are connected directly to the switched output through the main switch.
These are normally Orange and red and you can confirm by connecting orange to switch and red to power or vice versa., (checking by setting memory and switching off to see if it resets to reverse)
Your problem will be solved . Please comment if helpful
Posted on Aug 31, 2010
  • mikestav Dec 30, 2010
    I had same problem with my JVC deck... turns out the constant 12v and the ACC 12v wires where switched around! even my Haynes repair/service book was incorrect the wire diagram stated the color coding was correct but in fact it was the opposite... and im talking about the wiering before the cars wiring harness... easy fix!
Radio stuck in safe mode, holding the PSCAN and RBDS buttons doesn't display the "1000" where I am able to enter the code.
first off is it the original stereo that came factory if it is try this solution:
1:turn ignition on but do not start
2: turn on stereo
3: do not touch anything else
4: wait 5-10 with stereo on and ignition on 10 min to be sure
5: after 10 min turn of ignition only remove key exit vehicle
6: set alarm
7: wait 10 more min
8 disarm alarm
9:put key back in ignition and set to on do not run
10: stereo should now work
Nov 14, 2016 | Audi Cars & Trucks
Equalizer setting
memory dead or control chip bad..dealer item
Jan 01, 2014 | Cars & Trucks
It became only while the car was idling, now it's anytime, anywhere, and never on a consistent basis. The engine simply dies, turns itself off. When it happens, the check gauges light comes on. Nothing...
is your stereo the OEM (factory original) model? Does the car have a factory-installed anti-theft system? If the answer to both is Yes, you may have a logic conflict since many anti-theft systems go to and through the car's stereo. If you still have the original owner's manual, check the section on anti-theft or security systems. It may list a reset procedure that returns the system to factory defaults. If you have an aftermarket anti-theft system, you may have to disable it until troubleshooting and repair processes have been accomplished. Incidentally, by the car sitting without a battery for five years, all E-prom programming may have been degraded or lost. As for the volume increasing, some GM/Delco radios have a volume compensation feature that increases volume levels as speed increases.
Oct 10, 2013 | 1997 Pontiac Firebird
I recently purchased a JVC KD-R521 car stereo, was i have set the demo to off, clock set and radio stations programmed and turn ignition off it just goes back to factory settings. its driving me mad
try switching the main red and yellow power wires on the link harness with the shrouded push in connectors - i had the same problem and all sorted now!
Sep 13, 2011 | JVC Car Audio & Video
Screen froze
The normal method is to disconnect the power supply for 5 minutes.
Make sure you have the code ( if one is required for this model)
Jul 01, 2010 | JVC AM FM CD DET FACE CAR STEREO
I recently bought a JVC KD-R311 car stereo, its a great stereo but my settings dont save, for instance i set the perfect sound adjusting bass/treb/mid/loudness and whenever i turn my car back on after...
You need to have the yellow wire from the stereo connected to constant battery/12 volts. That wire supplies power for the memory, if it is connected to ignition power, when you turn off the car, the power for the memory is off also.
May 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
Set the clock on a JVC car Stereo KD 200.
That is a confusing one
1. Press and hold SEL to enter the program menu
2. Use the UP/DN arrow to select CLOCK H
3. Turn the dial to set the hour
4. Use the UP/DN arrow to select CLOCK M
5. Turn the dial to set the minute
6. Press SEL to finish
Nov 10, 2009 | JVC Car Audio & Video
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
JVC KDG340 memory problem
Your power wires are reversed.
Switch the red wire (Ignition switched) and yellow (constant 12V).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
486 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
