Question about Sanyo PLC XU35 Multimedia Projector
Counter Reset I changed the lamp but when starts counting with blue fullscrenn from 0 to 30 the lamp turns off. At the users manual says that i have to reset the counter but it dosen´t say how. Please can you help me with this? PLC-SU32 Sanyo videoprojector (Is the model that i own not the PLC XU35
  • Anonymous Aug 21, 2008
    Yes, I was the same problem solution
  • Anonymous Mar 21, 2014
    Where can I find the lamp counter for reseting the lamp counter for Plc-xu75 Sanyo projector
  • 3 Answers
Welcome to resolve the problem if you please say what are the solution to me the same problem
Posted on Aug 23, 2008
Reset lamp counter without OSD
press the "help" button for 30 seconds
Feb 14, 2014 | Office Equipment & Supplies
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Instructions on changing bulb
Turn off the projector, unplug the AC power cord, let it cool for 45 minutes.
remove the screw that holds the lamp cover on.
remove the 2 screws that hold the lamp in. lift the lamp out by the handle.
replace with new lamp and do the reverse.
reset the lamp counter.
press the menu button.
go to setting menu, then to lamp counter, press select button, select reset, select YES. then YES aqain.
Apr 06, 2011 | Sanyo PLC-XT25 LCD Projector
How can you view the amount of bulb hours for an Eiki LC-986?
The manual for your projector is found here:
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_x986.pdf
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to
move a red frame pointer to SETTING Menu icon (refer to page 37).
Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
Mar 03, 2011 | Eiki LC X986 Multimedia Projector
I need to reset my lamp counter on my projector pt-lc56e but i dont know how please help me
After changing the lamp you should be able to turn on the projector and it should run for approx. 10 minutes, allowing enough time to reset the lamp counter. Hit "Menu", select "Option 2", hit enter, which will bring up "Lamp Runtime", press and hold enter button approx. 3 seconds. The selection will change to "Time Reset (Power Off)". Turn off the power and it will reset.
Jan 26, 2011 | Panasonic PT-LB10VU Multimedia Projector
What is the lamp life on a sanyo plv-z2 bulb and how to read the bulb life there are 3 numbers that come up when i check it
If I remember correctly, you hold down either the power or the menu button for 30 seconds... I believe it is the power button, and it will briefly display it on the screen, but this assumes it was reset at the time the lamp was installed. The counter counts up on this model, and the lamp replace light will come on at 3000 hours. I have 2 of these units, and I have gotten at least 5000 hours out of each lamp. Toward the end of the lamp life, it may start getting dim and/or have difficulty starting, but I probably wouldn't replace it until you either notice the dimming or the lamp fails, although I've heard some say they can damage the projector when they fail, I have not had any problems.
Dec 03, 2009 | Sanyo PLV-Z2 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Lamp timer reset
Found in the owners manual.
It's important to reset the Lamp timer after replacing the lamp since the Lamp timer
will trigger the warning message. This can be done in Standby mode by pressing the
following sequence within 5 sec.
RESET, Left Arrow Key, right Arrow Key, ENTER.
This is also explained in the operation manual of the Lamp.
Jan 25, 2008 | Sony VPL PX11 Multimedia Projector
Lamp didnt strike
Hi there
You should reset the lamp timer as this LCD Projector's counter counts down the hours and will not fire up if this has not been done.
If you have reset the lamp timer and the problem stil occurs , you'll have to replace the Ballastboard ( lamp's powersupply )
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
461 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
