Question about Pool & Spa
I have an intex above ground metal framed pool, the filter pump is model #637 Krystal Clear. I made the mistake fo running it 24/7 for several weeks and now it is leaking, some internal seal must be broken...the motor still is running and it works, but I am losing water...if you flip the pump over there is a metal plate on the bottom of the motor casing, and it seems to be leaking from the seal for this metal plate where it meets the plastic motor casing. Any suggestions? Hate to buy another one when we really prob only have 1-2 weeks left to use it this summer here in NY! Thanks! Maggie
  • 990 Answers
You will have to set winterize plugs in the pool to do this.
Remove the pump and motor from the plumbing. Then with the power off pull the wireing or simpley unplug the pump. Now all you need to do is take the whole thing to your local pool store and they can replace the seal and gaskets for you. Generally they will do this for the price of the parts or maybe a small fee. All pumps are different so this is the best way to get this done.
Posted on Aug 31, 2010
  • gsdlady28 Aug 31, 2010
    Thanks! Got it fixed...hose fitting actually was loose and leaking water into the pump and water appeared to be leaking out of the pump, but once I tightened the fittings all is good...a lot easier and cheaper than expected!
  • Kieran Ruppert Aug 31, 2010
    You know what they say "This stuff must be easy, I can do it"
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
24'x52" Pool is 1 week
sounds lik air is trapped or you need a seriious backwashing. If it was running without a basket in the pot by the motor then you could have a clogged impeller. motor runs but not much happens right what is the pressure gauge reading when pool is running?
Jun 30, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
What is the best model filter pump for an 18' X 48" intex metal frame pool?
No doubt about it the Intex Krystal Clear Deluxe Saltwater System & Filter Pump. No more chemicals to add and no more money to spend. Just buy salt. Could not be easier. I own one myself. http://www.intexcorp.com/saltwater_02.html
May 31, 2010 | Intex "" Metal Frame Pool Set (56998e)...
All of a sudden the pool filter pump (637) quit working
The first things to check would be the breaker , there may be one near the pump and another at the main panel. Get back with your thoughts
May 11, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Which filters made by who is right for this model Krystal Clear 637
any b cartridge will do.
In fact off brands of the same filter hold up longer than intex brand.
This is my 3rd season with the same cartridge. Just blast it with your garden hose on high presure and you should be good to go unless you get a tear in it
hold cartridge and spray outside from top to bottom all the way around.
now turn it over and do it again.
you should do this at least twice a week and you will be good to go
Jul 14, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Apr 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
145 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
