Question about George Foreman GR10AWHT Indoor Grill
Hi, I have a GF model 13185 which went "pop" the other day and something was then rattling away inside. I found that a spot weld stud for an earth connection had sheared off. I got over this problem but there was still no circuit between live and neutral. The elements and the thermostat checked out OK and I have finally traced the problem to a component which is fitted in line between the incoming live and the bottom element. This is about 1/2 inch in length, has a white pointed end but I can not decipher the markings. Your help re what it is/can I get a replacement would be very much appreciated Regards, Brian Bucklar
  • 944 Answers
This is a new company so the parts are not available through online
This is the official website where you can get the parts for George Foreman
www.fox-international.com or call (800) 233-9054
Phone Number: 800-738-0245
800-231-9786
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
E-mail: applicaconsumeraffairs@fox-international.com
I can't exactly get what part you are trying to say.It might be Fuse i believe...
Yes you can't replcaement very easily because the company doesn't sell parts outside.But feel free to mail them.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Aug 31, 2010
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
Sharp Aquos 37" LCD TV sound quit
You could open up the TV and look for signs of burnt components then try to replace the components or try to find a replacement for the entire affected board on ebay or something. If you can find out what the problem is maybe the service person will lower there price. $600 does seem very steap, it should be something closer to $60 an hour with maybe the first $60 as an estimate.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do i get the top bolt out the nut just comes off
If you are trying to remove a stud (a screwed bolt fixed into a metal block) try using 2 nuts. Screw them on and tighten them against each other with 2 spanners. Once tight, unscrew the lower nut. The top nut will stop it moving up the stud and should start turning the stud. An alternative way is to spot weld (tack) a nut onto the stud. Either way turns the stud into a kind of standard bolt.
Oct 27, 2015 | Cars & Trucks
Timing chain cover
the fix will be to remove the timing cover and that will leave the broken bolt as an extension which you can grip with a pair of vice grips to undo
Mar 23, 2015 | 2002 Chevrolet Chevrolet TrailBlazer LS
Wheel stud
splines? you meant treads?
remove wheel, then drum. no year stated , but some years
have drum bolts, ,
see 2 screw holes in the dump, insert 8mm bolt to hole
screw in both bolts an drum pushes free.
the drum is off, , remove stud , put in new stud.
or if the new stud dont fit, the drum is bad. new drum time.
Sep 28, 2013 | Suzuki Sidekick Cars & Trucks
Loud rattleing from exaust
Rattling from exhaust indicates a failure or parts. Check that the cat converter is in one piece and not collapsed . Check mufflers for holes where the baffles inside are spot welded indicating loose baffles. Check for loose /rusted mounting brackets. Check for broken pipes and manifold fittings.
Sep 22, 2013 | Lincoln Town Car Cars & Trucks
When running metalic vibrating sound from muffler
Hi there
Just take it into the exhaust people and tell them that you need a new muffler ONLY. welded into the place of old one as all your problem is the BAFFEL plates have come loose and the welding is only spot welded and isent any good So a new muffler is ALL YOU WANT
Ron
Nov 08, 2009 | 2002 Ford F150 Regular Cab
Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
May 24, 2009 | Hobart Welders Champion 500433A Factory...
Spool wire starts to melt while on the spool
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Feb 16, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
George Foreman GR10AWHT Indoor Grill Logo
61 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
