Question about Mr. Heater Mr Heater Portable Buddy Propane Heater
Mr Buddy portable heater Model MH18B control value won't turn
  • 1 more comment
  • m_gauna Aug 31, 2010
    I can only turn it from off position to pilot position. It will not turn any further.
    The heater has only been used with the small 1lb propane bottles. But they have been left connected when not in use. Could these react the same way as the 20lb bottle?
  • 2,272 Answers
Turn the valve counter clock wise to open in and clock wise direction to close it.if its got stuck on any position,then move it on both direction and then move counter clock wise to open the valve. Check out.Keep updated.Thanks.
Posted on Aug 31, 2010
  • raj somaiya
    raj somaiya Aug 31, 2010
    When one uses this heater with a 20 lb propane bottle & accessory hose, it is imperative that you always shut the tank off first & let the heater run until it burns off all the fuel in the lines.
    If one simply turns the heater knob to the off position, it will trap trap 100 PSI of propane in the accessory hose. When high pressure propane sits in the rubber hose, it will chemically react with the rubber and leetch a light oil. The oil will build up and quickly work its way into the heater, clogging both the regulator & control valve.
    Another very important recommendation is to purchase the gas line filter. This will catch the oily residue and protect the combustion components of the heater should one forget to follow the precautions above.
    Thanks for keeping updated with the query.
  • raj somaiya
    Yes it can be possible.That that is causing the valve lines getting clogged and not letting it to spin.Heat it a bit and release the gas /oil/fuel and get the lines cleared and check.
    Thanks for keeping updated with your query.
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one-http://www.mrheater.com/product/faqs/little-buddy-troubleshooting/ Then Amazon http://www.amazon.com/Mr-Heater-Pilot-Assembly-Portable/dp/B008DBRB8W Make sure it's the right one for your model heater.0810snp
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
When mr heater portable buddy is on for about 30minuts control valve sticks on high and even on low when heater cools moves it moves freely
The solution is to contact Mr. Heater tech support. Once I made contact with them they took my complain very seriously and wanted immediately to inspect my unit. They issued a FedEx Pickup request to take my unit back to Ohio. They're sending me a replacement unit which they promised to test before send it it me.
Jul 16, 2012 | Mr. Heater Mr Heater Portable Buddy...
Mr. Heater MRH-MH18B. looking heat a unfinished basment about 1000sq ft
If you're asking if the Mr heater you referenced will heat 1000 sq ft, it won't. You'll need at least 32,000 Btu's to heat that much space. Either a gas mounted convection or infrared wall heater or a vent-free gas fireplace, that has a maximum heat out put of 32,000 Btu's should do the trick. Keep in mind, the air temperature in a basement, doesn't change more than 10 degrees F, thru out the year, so more than 32,000 Btu's is not better.
Hope this helped you and thanks for choosing FixYa.
Sep 12, 2011 | Mr. Heater MRHMH18B Gas Utility
My big buddy heater has sat all year and now it wont light
you may have cobwebs in the gas orifices. shut off gas and power then poke each hole out with a wire turn on gas and power and try again
Dec 13, 2009 | Mr. Heater MH18B
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Mr Buddy Heater Flameup on ignition
It sound like the pivot inside the regulator is damaged. I think that you will need to replace the regulator.
Jan 05, 2009 | Mr. Heater Portable Buddy
Heating & Cooling Logo
742 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
