Question about HP Cameras
The part that slides over the batteries is broken and will not clos properly can i get that repaired
    Genius:
  • 1,044 Answers
Have you tried joining it with any of the quick setting glues which are available in the market. Try it you will succeed in joining it. Otherwise go to your local dealer and ask him to get you that part. Or Go the the web site of HP. In the support section order the part.
Posted on Aug 31, 2010
Testimonial: "thanks"
Squelch not working
If it is a new scanner and I were having that problem I would use the warrenty and send it back to them to repair . Now if you did anything to it they will still repair it but you will be charged.
Jul 21, 2016 | Uniden BC-248CLT 50-Channel 10-Band...
Bose Wave CD: put in disc the screen reads "not playable". Need a repair place clos to Toronto , Canada
try a cd/dvd cleaning disc first- could be as simple as dust inside on lens
May 30, 2011 | Bose Wave Radio
Battery connection is broken on a SM 58.How do you get the components out after slip ring removal to repair the posts for a 9V battery?
There are some clips inside, those are holding it together.
You can slide thin plastic in it which wil hold those clips.
After that you can slide the body off,
Good luck,
Gerard
Feb 24, 2011 | Shure UT2 / 58 / PG58 Professional...
My blackberry9000 camera not working msg could not start camera close othere app.
my blackberry9000 camera not working msg could not start camera close othere app
Feb 15, 2011 | Cell Phones
Slide tray does not advance and slide does not stay in proper position
If the slide tray does not advance or reverse, the slide will not go into the optical "gate" AND the "SELECT" function doesn't work, then chances are that you have a broken mechanism drive belt. The good news is there are all kinds of projector parts still available at: www.micro-tools.com The bad news is that unless you have a service manual and have been into a projector before, this is probably a repair best left to a factory-trained repair dealer.
Jan 22, 2011 | Kodak Carousel 5600 Slide Projector
We have a trans sport se 1994 model. A light that looks like a miniature version of the van shows up on left side of dash near where the tail gate ajar warning would show up. The battery has run completely...
A quick guess is that one of the power sliding doors is not closing properly or the switch for that door is broken. A broken door switch would leave the door motor or interior lights on continuously and drain the battery. Draining the battery more than a few times would ruin it. Also check the front door switches for broken or missing actuators - the door ajar icon looks similar to the sliding door open icon.
I tried to download an owner's manual so I could be sure I was interpreting your dashboard icon correctly, but the oldest one available is for 1999, so my information may not be accurate.
Jan 17, 2011 | 1994 Pontiac Trans Sport
I have Hampton Bay fan and i do not know how to reverse the fan to the cool breeze for summer.
mcdevito75 here, There should be an additional switch, close to the fan swich on the fan motor to reverse the fan, Usually this is another shorter pull cahin just about 2 inches away from the fan switch (pull chain) this switch can also be a toggle or slide switch.. It"ll be clos eto the fan swich on the fan itself.
Jul 20, 2010 | Hampton Bay 13087 70450 Carousel II...
AF-3 carousel, lamp on but light guard prevents picture
Based on your description, I suspect the coil spring that tensions the "dark shutter" has either broken or has popped off it's mount. To be absolutely sure, take your projector to a factory-trained repair dealer.
Feb 13, 2010 | Kodak Ektagraphic III E Plus Slide...
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve (SCBENDER@AOL.COM).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Cameras Logo
88 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
