I have a bosch 16h hydropower gas water system that seems tempermental in that sometimes it decides to create a spark to light the gas and at other times no spark with resultant cold water being drawn. What could be the problem as the system is only 4 years old
  • ted keegan Mar 04, 2012
    Volts were 1.1 instead of 1.8. Gave it a tap and went up to 1.3 and started to ignite.
  • ted keegan Oct 17, 2012
    Take generator apart (6 screws ,2 clamps ,unplug red & black wire)Twist top off & clean moving part.
I had a similar problem replaced hydogenarator ok for a couple of weeks no spark again replaced ignition unit still no good bosch told me to bypass the switch works fine and also test voltage when hydo genarator 1.8 volts i just made a wire to join the two wires from back of switch. trav
Posted on Sep 18, 2010
  • 828 Answers
You need service as the ignition has a problem.
Posted on May 09, 2008
  • James Helmer
    James Helmer May 10, 2008
    Service cost are Dependant on the service companies need or greed. Repairing the problem would be more economical than a replacement. Shop around and ask for prices for the repair and then choose.
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Hot water goes cold
Did you find a solution because I am experiencing the same problem, but only since i change to a new shower head?
Regards
Christine
Feb 07, 2010 | Bosch Cooktops
Bosch gas hot water system won't turn on
i have a bosch 16h hydroflow hot water system that will not ignite.
Mar 27, 2009 | Water Heaters
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Dec 04, 2008 | Bosch & Tankless LP Hot Water Heater
Bosch Hydropower 16H instantaneous gas hot water unit not firing??
we had this problem and no plumbers were able to fix it. Finally we got someone from Bosch around and they found part of the ignitor had been installed upside down, since then no problems at all.
Jul 13, 2008 | Heating & Cooling
Our Bosch 16H Hydropower shuts off 30 secs to a minute after heating has started. We have used a variety of settings and only when we have the lower dial on minimum (fully anticlock) and the slider above...
Hi John
The manual is very limited in information it said to check there is
  • high water flow going through your system
  • and check your gas settings is correct!
  • The slide adjustment is your gas flow, which regulates your temperature
  • I have also increase the the gas regulator, which increases the gas flow
I have also been told its not a good idea to have a water saving head on your shower as this restrict the water out put.
Jul 03, 2008 | Heating & Cooling
Bosch h16 hydropower gas water system
Cost for both parts and labor vary for one end of the country to the other so I would have no idea what the cost would be in your area.
May 10, 2008 | Heating & Cooling
Heating & Cooling Logo
1,953 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
