Question about Whirlpool Duet GHW9150P Front Load Washer
I getting a funky smell in my laundry room and bathroom, but only when I am doing laundry. I am wondering if it has something to do with the hose. Its be like this for about six months.Thanks
    President:
  • 670 Answers
It probally mildew growing inside the wash tub and associated water connnections like the pump housing, drain hoses. Mildew growth is common problem with front load washers. You can try to reduce the occurance of mildew by leaving the door and soap dispenser door open when not in use. Also wipe with door gasket with a rag to dry it.
To kill the mildew in the machine wash an empty load with hot water and vineagar about once a month. Repeat as neccessary. There other products to help reduce mildew such as affresh. Hope this helps you.
Posted on Aug 31, 2010
Tip
We purchased our Kenmore front loader when they first came out. Shortly after,...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes smell like body odor after washing. using tide ultra he2 detergent.
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
Aug 13, 2010 | Washing Machines
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whenever I start my LG washer, it smells like sewage in my Laundry Room and then the smell goes away? I have tried running my laundry room sink to see if it's a plumbing issue but that doesn't work.
sounds like you need an anti syphon valve to be connected in line with your washing machine waste water outlet
Check that hose discharge from washing Machine loops up above the minimum height as specified by the machine manufacturer and at least to the underside of the work top for an inset sink before connecting into the sink trap.
http://www.wickes.co.uk/invt/420182
Oct 21, 2009 | LG WM2688HWM TROMM SteamWasher
Sulfur smell from the Delta faucet sprayer. Every morning, or when we have not used the spray for a while, there is a hydrogen sulfide smell that comes when we use the spray. We have tried starting flow...
maybe something funky is growing in the hose, try replacing it! call delta they will probably send you one for free! just tell them it's broken
Jun 29, 2009 | Plumbing
Washing machine + burning smell
The load of rugs may have been too much for the device and there may have been considerable belt slippage causing the burnt rubber smell. Try another regular load and cross your fingers. And stay away from those outrageous loads!
Sep 06, 2017 | Admiral AAV7000A
Rotton egg smell
The smell is simply residual biological washing powder doing its job and eating away at the mess and muck in the tube (along with the smell of rotting bits of lint and other rubbish. Dragging the garden hose into the house and flushing the pipes out with some clean water under pressure may help. Also, you may find thattitting the machine on its hottest wash, with about 4 dishwasher tablets in it may also help. Dishwasher tablets have detergent and anti-bacterial agents in them that kill the bacteria that is in biological washing powder.
Jan 03, 2009 | LG WM2496H Front Load
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
182 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
