Question about Canon IXUS i7 Digital Camera
My ixus 8515 says "card locked". The card has been broken, but a new one, wich is not locked, is placed in the camera. The display still says "card locked". What can I do?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
my ixus 8515 says
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 31, 2010
How o format new memory card to camera
Place the card in the camera (make sure the protect feature lock is not on), go to your menu settings and scroll through until you find thee "Format" setting. Use that and format the card in the camera, not on your computer.
Sep 28, 2014 | Canon IXY 31S / ELPH 500 HS / IXUS 310 HS...
Ixus 8515
Do you have a question about this camera?
Nov 22, 2013 | Cameras
I can take photo.. but i can't see it.. display problem. how much it will cost? ixus 8515
Cost of repair would be probably more than the camera is now worth. But is the screen just showing black? An issue with the tiny SD10/20/30/40... cameras (IXUS versions also) was that sometimes a little corrosion could form on the A/V plug switch that would in effect simulate the plug being inserted, thus turning off the screen. If you have your television video plug available, try inserting and removing the plug in its A/V port a few times. If this is the problem with your camera, sometimes this helps remove that corrosion, setting things right again.
Nov 21, 2010 | Canon IXUS i7 Digital Camera
Hi, my canon ixus 8515 wont turn on, any ideas?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 12, 2010 | Canon IXUS i7 Digital Camera
Hello I have canon IXUS 8515 and I want to know how can I cchange the (F stop)? thank you
I have looked in the manual and read a few reviews and it seems you cannot set the F stop yourself.
You need a camera with manual or aperture modes (AV).
Hope this helps.
Feb 21, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Camera is not taking out no pictures on display screen marks memory card locked
It sounds like the memory card has its little locking switch in the locked position. Take the card out of the camera and move the small switch on the side of the card to the opposite position. Re-install and you should be good to go.
May 19, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Instruction Booklet
Hi you can get it here at the following website address
http://software.canon-europe.com/products/0010374.asp
Benjamin
Apr 26, 2009 | Canon IXUS i7 Digital Camera
Availibility and price ?Canon Ixus 55 camera LCD display broken; mark on it SONY AM336BLAA
Perhaps you could Google it, there is a chance you may find it.
Aug 03, 2008 | Cameras
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon ixus 75 memeory card
On the SD card itself there is a little tab that slides back and forth. It should be closest to the the end you put into the camera first. If it broke off, then the camera is stuck in lock mode. If this is the case, it's not worth trying to glue something in its place...just invest in a new one.
Jan 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon IXUS i7 Digital Camera Logo
175 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
