Question about Logitech (980240-0403) Microphone
My Logitech Desktop Microphone's sensitivity is way to low. There is some sound when i tap it and talk extremely close up, but i dont think its supposed to be inside my mouth. Just bought it today. Thanks
You must uninstall from your computer the Realtek HD Audio Manager with your CD. Then restart it and than works! :D
Posted on Jun 01, 2011
Microphone muffled
Try to talk with your lips touching the mic . If there is any improvement open the mic housing very carefully and bring the capsule as near as possible to the top part of the housing .
hope this helps.
Sep 08, 2012 | Logitech USB Desktop Consumer Microphone
I have a logitech desktop microphone and i have it pugged in and enabled but i do not get any sound when i talk into the mic
In your Control Panel's Sound Settings, make sure the recording device is selected to the Logitech. That's usually the place to fix your issue.
Jul 12, 2009 | Logitech Audio Players & Recorders
I'm thinking of buying Logitech USB Desktop Microphone but I want to know if it works well with multiplayer games because that what i would use it for. I haven't been able to find any info on how the mic...
Yes, this mic does work well. Headset usually work the best, but I do know a few people who use this mic for their gaming.
Control and convenience
  • Advanced digital USB: Experience superior sound clarity with the simplicity of a single USB plug-and-play connection.
  • Noise-canceling microphone: Filters out unwanted background noise.
  • Power switch: Illuminates when microphone is active.
  • Adjustable microphone: Pivots on base to hold preferred position.
  • Eight-foot shielded cord: Gives you more desktop flexibility.
  • Mute switch on base: Instant and easy muting.
  • Weighted base: Adds stability.
Technical Specifications
    • Frequency response: 100 Hz–16 kHz
    • Input sensitivity: -67 dBV/µbar, -47 dBV/Pa +/- 4 dB
    • 8-foot shielded cord with USB connector
    • Connector: USB 1.1
YOU CAN GET USER REVIEWS HERE:
http://www.google.com/products/catalog?q=logitech+usb+desktop+mic&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&cid=16452149199579405298&ei=GyxWSr-ePIrQM7aJvZ0I&sa=X&oi=product_catalog_result&ct=result&resnum=5#ps-sellers
Jul 09, 2009 | Logitech USB Desktop Consumer Microphone
Dont Know How To Turn On Microphone on webcam
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 25, 2008 | Logitech QuickCam Communicate Deluxe...
When I am talking the person on the other end is not hearing my voice. THis is a new install onto my laptop
Hi Stephan,
Open Skype and login. Now go to Tools, and Options, now click Audio settings and try switching the microphone settings between Windows default settings and any sound card driver you might be using (I am using the RealtekHD Audio codecs, for instance) and you'll be able to see the level that both Windows audio device, and the sound card driver, is set at, and you'll see the levels bar reacting to any sound you make. If the levels are too low, then you have to go to either Windows Volume Control or the Sound Card Sound Manager and adjust the microphone settings there.
A lot of people have this problem at first run, so don't think you're alone!
Hope this helps
Chris (ziraffa)
Dec 23, 2008 | Logitech Quickcam Chat Webcam
Pcchips A13G+ motherboard sound issues
You may not have a choice. The jack could be loose or have a bad solder joint. If the microphone is "staticky" on this system but not on another, then increasing the volume will only increase the static.
You can try a condenser microphone. Condensers require their own power (battery) and output a MUCH higher signal. High enough for the Line-In jack.
If you are using the microphone for voice chat or internet phone or gaming or similar, I STRONGLY suggest a USB headset, such as you can get from Logitech. You wouldn't believe the quality difference.
Jul 06, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
How to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Apr 24, 2008 | Logitech USB Desktop Consumer Microphone
Sound Problems
that is a very good awnser go with him
Mar 27, 2008 | Logitech Quickcam Chat Webcam
Audio
This clearly is some kind of device configuration problem..Open control panel->sounds and audio devices->voice Now click on test hardware and tap on your microphone and see if the sound meter is showing changes..then click next and tap again and see if you are able to hear it in your speaker. If you cannot just download the latest device drivers for your sound card and that should fix the problem! Also you can download latest drivers for your webcam here http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/LOGITECH/Logitech-QuickCam-Communicate-STX.shtml Try both of these and hopefully you will get it working!
Oct 06, 2007 | Logitech QuickCam Communicate STX Personal...
Open Questions:
See all Logitech (980240-0403) Microphone Questions
Logitech (980240-0403) Microphone Logo
288 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
