How do i stop the cartridge holder in the right place to replace the ink cartridges ?
  • 48 Answers
In most printers the carriage come to the center when you open the top cover. Sometimes the carriage will go all the way to one side before returning the the center if you give it a min it should stop in a place where you can replace the inks. It it's not then you may have a problem with the printer.
Posted on Aug 31, 2010
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
Where is the toner cartridge and how do I find it?
Plug the Lexmark 2600 into an electrical outlet and press the power button. Allow the unit to power up. The power button will turn green when ready.
Turn on the Printer and Open the top cover of the Lexmark 2600 by lifting the cover upward. you will find all cartridges down there.
Now you see how to replace them
Remove the black ink cartridge from it's packaging. Remove the tape from the black ink cartridge first and place the cartridge into the left ink cartridge holder. Press the cartridge down into until you hear it lock into place. Close the ink cartridge holder lid by pressing it down firmly. This secures the ink cartridge in place.
Remove the colored ink cartridge from the packaging and remove the tape from the cartridge. Place the cartridge into the right cartridge holder and press down until it clicks into place. Push down the cartridge holder lid.
Close the lid of the Lexmark 2600 and allow the print cartridges to align. The power light will be blinking while the cartridges are being aligned; once the power light turns solid, the printer is ready for use.
Do rate, if found helpful
Nov 27, 2010 | Lexmark X2600 InkJet Printer
How to change the ink cartridge in a Canon iP1900 printer please
1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
•2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
•3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
•4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
Aug 18, 2010 | Canon Office Equipment & Supplies
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
How do i eject the ink carrier?
hi there,
  1. Look at the Epson printer's LCD screen to see the ink levels for each cartridge. If your cartridge is completely empty, simply press the "Color" button. If your cartridge has a low ink level, press "Setup". Hold down the button on the upper left side of your LCD screen until the words "Replace Ink" appears, then press the "Color" button.
  2. Wait until you see the words "Open the scanner" on the LCD screen. Then lift open the printer top by pulling up on the side grips next to the scanner unit. Make sure that the scanner lid remains closed. The ink cartridge holder should move to the far right of the printer.
  3. After the cartridges have completely stopped moving, pull the cover of the ink cartridge holder up and toward you. Press in the tab of the cartridge you need to replace. Lift the cartridge straight up to pull it out of the holder.
  4. Unwrap the replacement cartridge and insert it securely into the holder. Press straight down until the cartridge snaps into place.
  5. Close the cartridge holder cover and make sure it clicks into place. Close the scanner unit and wait while the printer charges the new replacement cartridge. Wait until the word "Charging" disappears from the LCD screen before using your printer.
Do not turn off your Epson printer while the "Charging" message is still on the LCD screen because this may cause your inks to not fully charge. Turn off your printer only if there has been no response for over five minutes.
Clean up any ink spills with soap and warm water.
Replacement ink cartridge: Black (T048120); Cyan (T048220); Magenta (T048320); Yellow (T048420); Light Cyan (T048520); or Light Magenta (T048620)
Hope this initial info/idea helps.
Let me know for further instructions.
Thanks
Apr 29, 2009 | Epson Stylus RX500 All-In-One InkJet...
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Epsom Sytlus DX4450
Using the Ink Cartridge Replacement utility in Windows
1. Open the Printers window by following the appropriate steps for your operating system.
In Windows 2000: Click START > SETTINGS > PRINTERS.
In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
2. Right-click your printer model and select PRINTING PREFERENCES.
3. Click the MAINTENANCE tab.
4. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Caution:
Never turn off the printer while the On light is flashing or you’ll waste ink. If the ink light flashes, press the Stop button and press down all the cartridges securely.
Using the control panel
1. Turn on the printer.
2. Open the scanner and make sure its support locks in place.
3. Press the STOP button. The print head moves to the ink mark to indicate which cartridge is low or expended.
4. Press the STOP button again.
If another cartridge is low or expended, it moves to the ink mark. Press the Stop button again to see if more cartridges are low or expended.
If no other cartridges are low or expended, the print head moves to the replacement position on the right.
5. Open the cartridge cover.
6. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7. Before opening the new cartridge package, shake it four or five times.
8. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
9. Remove the yellow tape from the bottom of the cartridge.
Caution:
Do not remove any other labels or seals, or ink will leak.
10. Insert the new cartridge into the holder and push it down until it clicks into place.
11. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
12. Release the scanner support and close the scanner.
13. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
Caution:
Jun 05, 2008 | Epson Printer
jasbo
jasbo
