HOW TO REMOVE GP 555 DRUM
What kind of Canon copier are you looking for a GP-55???? And the error code E5F7 is not a Canon error code. Relook at the error code again and let us know what it is displaying... It could be a finisher problem.... Try to disconnect the finisher and see if the code shows up??? If not it is in that unit. Is the stapler jammed or the sorter bins broken???? Need a place to start.
I'm not too familiar with your machine. Its a bit before my time, nut from the info that I have, the problem is with the finisher. I would suggest that you get a canon technician out to have a look at it.
E805 (The fan rotation is faulty.)
If no detail code is indicated,
suspect the feeder fan (FM1) or the
reversing guide cooling fan (FM9).
Is the connection of these fans
normal? Is the drive signal of the fan
identified in the previous step about
22 VDC while the fan is rotating orabout 12 VDC otherwise?
That is one side with the fans,
Secondly, if the fans are found right, then for sure you need to change the DC Controller.
Regards!
Originally Posted by logimix
Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
