Question about Dynex 32 in. LCD Flat-Panel HDTV
Remote was working fine.all of a sudden it stopped working.I put new batteries but still don't work.What could be the problem?
  • 3 Answers
First of all check if the remote is working. How do we check the remote? Use your phone camera. While watching the LED in the remote through your mobile camera, press any remote button. You should see the LED flashing. You can't see the LED flashing by naked eye but with the help of camera you can. If the remote LED transmit the signal (if it flashes) then the remote is working fine. In this case your TV has the problem. If you can't see the LED flash, then your remote is the problem.
Open up your remote and check if there is dry or broken connection, or short connection.
Posted on Sep 05, 2010
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
My comcast remote was working with my Motorola dct700/us box and now suddenly stopped working
Put in new batteries or check that the battery contact points inside the remote are free of rust or acid build-up from leaking batteries.
Dec 06, 2013 | Arris DCT700 DTV Receiver
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Remote key lock stopped working after wal mart put new battery in and now my head lights stopped workin!!!
check fuse for low beam, then possibly both low beam globes. they could have blown.
the key remote may need reprograming into system try put key in ignition in on position then press remote buttons a couple of times then try if no good need to go to dealer to be programed into system again or it needs repairing/replacing.
May 31, 2009 | 1996 Chevrolet Camaro
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Dec 21, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
122 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
