Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet ht has a code F02 displayed and i dont have a manuel
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!%#^
Posted on Sep 21, 2010
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
This error is shown on the display due to:--
Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
This Will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
Potential Causes
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f02
the f 02 means you have a long drain issue press pause/cancel twice to clear the display check drain hose make sure it isnt plugged or kinked check electrical connections at the pump make sure the pump is running check drain filter for foreign objects if the above does not correct the problem replace the pump
Mar 25, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
