My stereo amp is on standby. when i switch it on the display doesnt light/show up and i cant get no sound out of it! Ive tried changing the clear fuse and had a quick look to see if there are any malfunctions but i cant see myself ...
  • 4,234 Answers
In all probability, the unit is in protect mode. See the link below for starters and post any additional questions you may have here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Aug 31, 2010
On standby mode the display shows 4 dashes,when power button is depressed display reads good-bye and returns to 4 dashes.why wont amp switch on
seems like the amp could be malfunctioning with its logic board having some issues i cant say much since most logic boards arent always easy to repair...
Feb 23, 2017 | The Audio Players & Recorders
Fm stereo stopped working; no stereo beacon, no sound
Hi... try factory reset: while holding down VCR/DVR button ,press the ON/STANDBY button. "Clear" will appear on display ,and receiver will enter standby mode. :)
Jan 20, 2014 | Onkyo TX-SR876 Receiver
Toshiba TDP ST20 projector standby problem
(Ah, I didn't see this box before I logged in, and now I can't delete the "comment" that says the same. In any case, copy annnnnd... paste!)
If it's an orange or grey + orange coloured one, with no controls on the body other than the two service buttons, then it's been ripped off from a Smartboard interactive whiteboard system in a school, college, office, etc - either by a thief, or during a genuine but misguided stripdown whilst the system was being junked. It won't function without being connected to the rest of the system. The light sequence you see is normal for it being connected to the mains, giving an "all clear" indication, then settling back into standby. You MIGHT be able to make it work with a suitable remote, but it does sound mostly that you're running into an anti-theft lockout...
It's for the best, they're rather fragile and wear out somewhat quickly. Get hold of an NEC or HP or something instead, they're rather more hardwearing.
May 18, 2012 | Office Equipment & Supplies
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
Problem with legacy amp
I would check the RCA preamp wires connecting the stereo to the amp. If these are loose or broken, it could cause you to lose your sound.
Does the amp show signs of life, such as clicking on, an LED turns on, or anything like that?
Has anything else changed between the time it worked and didn't work?
Mar 20, 2008 | Legacy - American II: 2 Channel 2000W...
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
27 people viewed this question
 Grubhead
Grubhead
