Locking a linksys pap2
Thanks for the advice. i have tried the settings you have provided and it works!! thanks. how do i lock the pap2 so that even if someone rests the pap2 it keeps the settings?
  • 24 Answers
Hi rajahc,
If that is the later version on PAP2 with the reset button on it, I'm afraid there's no way to fully lock it out, but if that is the earlier version without the reset button, there is a way to fully lock the unit from both web and IVR access, however you would need the so called SPC tool, this small software will enable you to generate the generic configuration file for the PAP2 so could you modify it, re-compile and upload it back to the unit via a tftp server. Its not an easy feat not to mention that those SPC tools are only issued to a few selected Linksys partners. Hope this helps
Cheers and best regards,
P.S. pls rate me, tnx.
Posted on May 09, 2008
My linksys pap2 cannot ring the wireless set or a fax machine.
Try changing the power supply.
It could be unable to supply the neccery power...
Jan 15, 2013 | Linksys PAP2T
Hello, I have a Linksys PAP2-VN VoIP adapter from Verizon Voicewing which you know is now defunct. I cannot access the web setup utility because it requires a password that was set up by Verizon and I...
HelloThe Password/user name will provides you by Verizon, try admin:admin
Here is a list of the most prominent VoIP services providers of this type but better service:
1. Vonage 2. Lingo 3. Voip.com 4. BroadVoice 5. Packet8 6. ViaTalk 7. AT&T CallVantage
Hope it helps, if so do rate the solution Good Luck
Dec 28, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
How to lock a PAP device ....? i want to lock a pap device to make my voip account secure..
  • Open a web browser on your computer and navigate to the IP address of your router. This address is typically "192.168.1.1" or something similar.
  • Type in your current password and press the "Enter" key or click on the ok button
  • Click "Administration" to access the password alteration screen.Type the new router password two times and then click on the "Save Settings" button to immediately change your router's password.
  • Hope this helps, thanks for using fixya.
    Correct? vote wouldnt go a miss good or bad.
    Dec 06, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
    I have an unsecured router ,linksys wireless-g 2.4 ghz broadband router,need password and username to secure it.
    There is no need to ask for a username or password. Just log in the settings' page for your Linksys with your browser (typically it's http://192.168.1.1), provide the username and password to connect with the router and make the settings you like for the Wi-Fi name at WLAN SSID section and the password you like at the security section. At the end hit apply (or save). I advice you to make all these settings while you are connected with an ethernet cable at your Linksys, to avoid being locked out in case of a problem.
    In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct FixYa link: http://www.fixya.com/users/technical114
    Nov 09, 2010 | Linksys Wireless-G Broadband Router
    Lost my password
    Hi Friend,
    The Linksys PAP2 Device is a user friendly device.
    The solutions is u must reset the router to the factory settings i.e., to default setting
    u will be having a reset button at the back side of the router ,hold it for 5 to 10 sec and release the router will be getting on automatically then u can configure again from initial.
    Regards,
    Ayyasam
    Apr 27, 2009 | Linksys Cisco SPA9000 VoIP Gateway - 1 x...
    Fax solution
    Hello!
    First check with your voip service provider that they supports T.38 over SIP.
    For sending fax you have to enable T.38 (fax protocoll) support in the pap2 webui.
    On your fax machine set data speed to 14.400 kb.
    But anyway T.38 (fax) over voip is not a waterproof solution, it can only guarantee delivery for about 85 to 95 % of sent\ recived fax's.
    Make shure you have a good, fast and stable connection (try pinging the sip server ip). If it doesnt try another fax machine (f.ex Brother or xerox). If that dosent work, and you still have to get a fax service, try a online fax to mail, mail to fax solution (search google).
    I can provide more detailed information and how to's if needed.
    Jun 05, 2008 | Linksys PAP2
    How can i unlock linksys mode pap2-vn?
    The only way so far to unlock this is to request Vonage to do it since the VN unit is locked to Vonage.
    May 31, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
    I have a linksys PAP2-NA VoIP adapter. I want to lend to my customers but want to lock the access to admin so they cannot see my settings
    Hi rajahc,
    That's easy (as long as your voip provider didn't locked it themselves), just log-in to your PAP2's setup page and set the user and or admin password under the system tab. Hope this helps
    May 09, 2008 | Computers & Internet
    Computers & Internet Logo
    193 people viewed this question
    David Payne
    David Payne
