All of a sudden, everything on my screen just turned on it's side...I am having to turn my monitor on it's side to see everything...instead of horizontal, everything is vertical..icons, everything....HELP!
    President:
  • 2,571 Answers
Control panel / display / change display settings and change the orientation (this is for win 7, so it may be slightly different for you)
Posted on Aug 31, 2010
I have a zx4351, touch sreen wireless gateway desk top computer , i had cable co. today to hook it and now my screen does not turn on and has no power going to it what is it?
Your desktop tower/cpu tower has to be turned on to give those hardware power. If you can't turn on your computer then that means you have an internal problem with your motherboard etc. If everything else powers up except for the screen/monitor your video is dead. Find someone you know that has an extra monitor and hook it up to your tower, if it works then it's not your video but the monitor instead.
Dec 01, 2012 | Gateway Computers & Internet
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Apr 20, 2009 | ViewSonic VP930b 19" LCD Monitor
ViewSonic monitor VS10780
i turn on after 30 sec turn off that happen all the time
Feb 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
Sep 28, 2008 | Acer Professional P211 21" CRT Monitor
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Display on moitor
just press the auto button on panel it will adjust the screen
Aug 17, 2007 | Compaq FP 7317 17" LCD Monitor
A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
