Question about Mr. Heater Mr Heater Portable Buddy Propane Heater
Knob to turn it on won't turn - Mr. Heater Mr Heater Portable Buddy Propane Heater
Element won't turn off
Bad control knob? Hard to say with out more info. To check if it is your control knob, you can unplug the stove, switch the wires from the nearest control with the one you are having problems with and then plug it back in. If you are now having the problem with a different element, then you can pretty much be certain its in the controls. Hope this helps.
Feb 06, 2013 | KitchenAid Kitchen Ranges
Temperature control knob not working
HAVE YOU PULLED THE KNOB OFF TO SEE IF IT IS CRACKED?
THEY SOMETIMES DO AND THE KNOB WON'T TURN THE SHAFT
Oct 23, 2012 | Chevrolet Colorado Cars & Trucks
Climate control selection knob is broken The knob would not turn and when I pulled it off a piece of plastic droped out and now the knob turns freely but won't change the settings from AC to defrost or...
If I understand correctly, the same thing happened to me. It might just be the knob, if you can use pliers to rotate the metal piece where the knob connects then either buy a new knob or you could hot glue the old one in place. Just make sure you have it pointing in the right direction if you do.
Oct 08, 2011 | 2002 Buick Century
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
'lll
Aug 17, 2011 | Dryers
How to remove spool from cap on a reflex plus strimmer
Usually these trimmer spools are retained with a threaded 'knob' with serrated edges. The problem usually is that the knob won't turn - or so it seems. You will have to hold the spool itself while attempting to turn the knob off - turn the knob counter-clockwise!! Remember - righty tighty, lefty loosie! I usually need to turn the knob with a large pair of alligator pliers to get its grip broken, then I can turn it off by hand. Good luck with it!
Jun 21, 2011 | Black & Decker Garden
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Heating & Cooling Logo
96 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
