Question about Whirlpool Duet GHW9150P Front Load Washer
Front load washer - compact, 24" (SAWB600JQ0, I think) - door won't open. we have tried 1) rerunning spin cycle (and it drains and spins), 2) unplugged for 5 minutes - no luck. Is there a manual overide? What does one do when there is no power? Any other ideas?
  • 1 more comment
  • kgnagey Aug 31, 2010
    did the test mode thing - light lit up nicely, door still locked
    I really don't want to put in a service call, as I am thinking of replacing the washer - I just want my laundry out!
    I have a tech savvy renter and I will show this to him. Of course, any repair/modification that requires the door to be open first is pretty useless. I am also not sure this is a Duet - it is a small compact "apartment" model. We inherited it. I love front loaders and used to have an AEG - it had a manual pull to open the door in case of power failure - what a great idea!
  • kgnagey Sep 01, 2010
    there is a new solution to add to this problem ;-)
    in our case it turned out, that the catch and lock hole do not line up properly -- for now the solution is a solid scredriver gently inserted into the opened door handle and gently twisted - it opens the catch! (but only if the door is set to 'open" ie program is finished)
  • 11,896 Answers
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Most common causes is the surge protector. By removing it. It will work great.
Posted on Aug 31, 2010
  • Nate Stansfield
    Nate Stansfield Aug 31, 2010
    This is one of the most frustrating faults to get, especially if your
    clothes are stuck inside the washing machine. Lots of people force the
    door open out of frustration and cause extra expense. There are many reasons
    why the door may be jammed shut -
    1. The water hasn't pumped out properly and the washing machine has a
      pneumatic door safety lock (a rubber hose connected to the door interlock
      and connected to a pressure chamber bottle on the tub - water forces
      air up this tube and locks the door) Washing machine won't empty water.
    2. The water has pumped out properly, but a blockage of gunge inside
      the pressure chamber bottle is trapping the air that's operating the
      door lock (if a pneumatic lock is fitted - not many have these days due
      to cost cutting)
    3. Door interlock jammed
    4. Door catch, handle, or mechanism broken
    5. ****** (a device that detects the motion of the drive belt fitted
      to many older Hotpoint washing machines which "pecks" at the
      belt when the door handle or button is operated) is broken or has fallen
      off
  • Nate Stansfield
    Nate Stansfield Sep 01, 2010
    If the catch and lock don't line up, try repositioning the door and hinges. It may have gotten warped or moved out of position during spin cycles.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link …
http://whirlpool.custhelp.com/app/answers/detail/a_id/2997
Also put in the unit in test mode. Put the program selector knob at the 6:00 position. Put the speed spin selector knob at the 9:00 position. Press and hold the pre-wash button and then press the power button. The 5 leds should light up. This will test the door lock switch. Hopefully it will unlock and reset. If not it's best to call for service as some complicated tests will have to be run.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Won't drain and spin. Cycle completes and all the lights on far right flash. Door won't open. Bottom of washer is filled with water. Tried putting it on drain and spin cycle. Still won't drain. Beeps...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Frigidaire Washing Machines
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
2009 Frontloading Electrolux washer door will not open!
When this happened in our home, we unplugged the machine, waited then plugged it in again. This reset the machine and the door immediately unlocked
Feb 18, 2010 | Electrolux EW1000i Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
