Question about Microwave Ovens
Microwave Drum not moving Problem - Microwave Ovens
  • Microwave Ovens Master
  • 17,130 Answers
Remove the plug and take the turn table out of the microwave cabin. Now keep the microwave rested on the side andopen the back pannel,you can see the turn table belt drive.If this is broken replace.if not trace the motor connection and mark them.Now heat the microwave in normal position,place the turn table and a cup of water.Close the door and switch on the microwave set for a minute.Now check the voltage on the motor line marked.If present ,then the motor is fault.If not the controller board is faulty, and must be traced.Can be the relay drive or the relay. hope the other sections are working fine.
Posted on Aug 31, 2010
Why does the microwave have the turntable keep moving/light stay on/keep vibrating whenever the door is closed?
< - contact me directly for free advice.
Remind me of your exact symptoms and the full model number from the tag in the cooking cavity or elsewhere on the oven.
May 10, 2014 | Sharp R-530ES Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Microwave wont heat
If it has a turntable does that move? If it moves and does not heat suspect inverter board (power) or less likely the Magnatron.
If table does not move it could be a issue with the safety switch which the door engages when closed.
Oct 14, 2012 | Whirlpool MH6140XK Microwave Oven
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
My beko wm6123s is washing and spining but is making very loaud nosies please can you tell me the prom and how to fix it?
It the fault is only about noise then it is important that you need to get a good look at the moving parts when the machine works.
Once you have some idea of the area of noise then shut down and remove the mains plug. Now manually turn the washer drum or the motor to confirm the place of noise. It can be poor bearings, displacement of the drum rubbling against the washer body or even faulty motor bearings.
Sometimes a drop of oil or grease ont he moving part will remove the noise.
Jun 06, 2011 | Microwave Ovens
Motor is going drum not turning
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 30, 2011 | Microwave Ovens
My GE microwave palte is not moving and the
One of the door switches is out of alignment/ or faulty.
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
