Misubishi warrior 2 intermitant pic freezes 1 second or less
    Genius:
  • 1,139 Answers
Hello frogman,
The freezing of the picture denotes a loss of signal on a digital (Having a ATSC tuner) TV. If your TV is not digital (Having a ATSC tuner) then it is the device that you have connected to the TV (Cable Set-top Box, DTV Tuner, etc). In the likelihood that it is your TV I would suggest getting a better antenna first if that does not fix the problem you may have a tuner problem. However lets not look at it that way first. What we need to do is to determine if it is the TV of whatever you have connected to the TV.
First unhook the connection you have from the cable to your F connector of the TV (you should see snow or a blank screen) connect a antenna to the F connector of the TV, do you see a snowy picture or a clear sharp picture (snowy= NTSC tuner, clear-sharp= ATSC tuner). If the tuner is NTSC then check you cable device and the connection between your TV and the device and the cabling between the device and the wall. If the Tuner is ATSC then you will have to check all of your connections, and finally if the tuner is bad it has to be replaced by a qualified Tv repair shop.
I hope this helps,
Thank you,
Shuttle83
Posted on May 11, 2008
I need to change my freeze plug for my 1997 Chevy venture van. And I need to know how because the transmission is in the way. Because when I put water in my radiator it pours water out of the back of the...
Good Article with Pics....
http://www.circletrack.com/enginetech/ctrp_0811_freeze_plugs/photo_01.html
Buy BRASS freeze Plugs (First Pic)
Pull the Freeze Plug Out. (Second Pic)
Use a Sealant or Locktite (3rd Pic)
Drive in with a Socket (4th Pic)
You need to pull the Freeze Plug out, clean the Block to ensure that is will seal in there good, Take a New Freeze Plug and a Socket. Then you want to seat the CURVED SIDE INWARD (The Bottom the of the Cup Inwards)....
511f3697-0d11-4cd0-8dc3-25efabf039fd.jpgf0d3b3ea-543b-4045-92b6-a2834a77aa76.jpg1513f71d-c426-46dc-9d82-8d9d9a5786cf.jpg50195c5a-748b-4465-9ddb-0bba5cc42bea.jpg
Apr 06, 2013 | Cars & Trucks
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
I cannot locate my owners manual for my Imperial upright commercial freezer. I need to know how to defrost it
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Apr 22, 2011 | Migali Imperial Series Aluminum Reach In...
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
Slideshow freezes during slideshow
I wonder if ALL the pic's are correct Size & Format?
Feb 01, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
P2370HDBL Samsung TV- BBC 1 and 2 picture freezes
While it is under guarantee, don't even think about it.....take it straight back for repair...
Jan 16, 2010 | Televison & Video
Power light comes on for 2 seconds and then off.
Need to have the power supply rebuilt, expect to pay around $350 Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Mitsubishi WS-55807 TV
Intermitant shut down will run less than 1 min
If you have a solder iron you can open up the relay can and re-solder the relay on the pcb. Real common for there to be cracked foils at relay.
May 01, 2009 | 1991 Honda Accord
My misubishi
Good day, fidel509; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Good luck, I hope this will get you started in the right direction, big IRISH.
Jul 18, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
