Question about Sony Cybershot DSC-S950 Digital Camera
I suspect moisture in the lens on my digital camera when I use the zoom. The picture is very foggy. When I don't use the zoom the picture is fine.
  • Sony Master
  • 17,130 Answers
Keep the camera in a warm setting with a constant flow of hot air. Now use a pack of dry silica gel along with the camera put it into a closed sealed nylon pack. Keep aside for few days and check.
If there was moisture as you hadd suspected then it would hahve reduced or gone.
However is there is still the issue , i would advice that you can show it to the nearestt Sony service to get an opinion. it does not appear to be serious than to open and clean the lens without disturbing the circuit.
Posted on Aug 31, 2010
    President:
  • 4,070 Answers
Hi! Your suspicion can be right but the other thing that can cause this is that the optic lens itself on the zoom is faulty. You may try to have it replaced now or soon. Just wait for the lens break point to maximize the usage, not unless you always use the zoom. Hope this helps and thank you for using FIxYa!
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
Apr 10, 2016 | Panasonic Lumix DMC-FZ28 Digital Camera
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
I have a fujifilm Finepix 2650 digital camera. I have run thru all its settings, even tried 'Manual' mode. But nothing makes any difference. It will auto focus inside when zoomed all the way, but...
Unfortunately it sounds like there is damage to the lens which is only fixable by replacing the lens assembly.
The labor involved plus the price of a used lens (a new one would only be possibly be available through Fuji directly if they will still repair the camera) would be far more than the value of the camera.
You can probably buy a used one on 3b@y for $30. (They don't pay me so I don't type their name)
Thomas
Sep 07, 2011 | Fuji FinePix 2650 Digital Camera
My SD800IS was working fine while in the very hot/humid environment of Yap. I took it out of my air conditioned room and went to take a picture almost immediately. The view finder, the LCD image and the...
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
May 06, 2011 | Canon Cameras
I would like to know why the camera is taking pictures so foggy. whenever u are taken a picture it looks foggy and it takes the picture foggy you can barely recognize the person even when you zoom it.
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 30, 2010 | Samsung Digimax D53 Digital Camera
Whiteout on fujifilm f20. how do I remove the lens?
Firstly, to isolate the shutter as the problem, turn the camera on and the flash off. put the lens into full optical (not digital) zoom. Then turn the camera lens to face you and look at the lens and take a picture.
With the camera in full optical zoom the shutter assembly will be right up to the outer lens so you can see it clearly. When the button is pressed you should see the shutter fire across the lens inside. It should cover the lens completely. If it does not or doesn't fire at all then you get over exposed pictures or lines across the photo. The most likely cause for this is moisture residue on the shutter leafs sticking them together.
To clean you will need to strip the lens down almost completely to access the shutter assembly. If this model of camera uses a sealed shutter unit then it will be impossible to clean. The only models i have found so far that use a sealed unit are the F460 and F470. Yours I am not sure of as I haven't opened 1 up but the solution for most is to strip it down and clean.
Tip: use another camera to photograph each stage to help on re assembly
Jan 18, 2010 | Fuji FinePix E550 Digital Camera
Fuji E900
Try the video function.
If this works fine then it is most probably the shutter sticking.
To confirm the shutter is sticking turn the camera on, put the zoom to full optical and turn it to face you so you can see into the lens. Watch the inner part of the lens when you take a picture. You should see the shutter fire across the lens. Lines on pictures or over exposed pictures are caused by gaps in the shutter or the shutter failing to fire altogether.
Moisture residue on the shutter leafs is the common cause for this problem.
Some people on here have their own views about what causes lines on photo's. Someone even said digital cameras do not have a shutter and problems were due to software issues....
I have dealt with 100's of different models, including Fuji's E900 and always have found moisture residue to be the cause.
Dec 11, 2009 | Fuji FinePix E900 Zoom Digital Camera
Hazy pictures on digital zoom and blueish cast
There are three possible causes for an hazy picture:
1. The lens is fogged:
Sometimes when you come out of an air-conditioned room, the camera is exposed to a sudden change in temperature. This causes a temporary fog inside the lens housing. If you snap a picture through this foggy lens, the picture will not be sharp and can lead to unwanted color casts on the picture. This situation can be avoided. Someone in a photography forum stated "Before going to the outside, put the lens in a ziplock bag and leave it outside till the body temperature of the gear changes to the outside temperature. When it does, take it out and use it, this way it will not fog up because there is no sudden change (to the gear) temperature wise."
2. A possible fungi on the lens surface:
When you use the camera in damp environments, there are a lot of chances of fungal growth on the lens surfaces. Fungus is a living organism that sometimes prefer to make your lens as it's home! Moisture supports its living and their presence really affect the image quality. You can avoid fungal growth by adding a small bag of Silica Gel to your camera bag. Silica Gel is a good absorbant and will absorb any moisture in the camera bag. But do regularly change the Silica Gel with a new pack. Do not store your camera inside a leather casing if you don't have to. Leather is a good material that can preserve the moisture. Always store your camera in a dry place.
3. Dirty lens:
Obviously you know the solution for this!
Just make sure you use only a piece of leather to clean the lens. Leather will not scratch your lens.
As for the blue cast on the pictures, it is the ultraviolet rays that casts the unwanted color. If you live in a sunny weather, this is not unusual. UV filters will solve this issue and is cheap too. UV filters also act a lens protector!
Hope these help you! Good luck!
Mar 21, 2009 | Fuji FinePix S700 Digital Camera
Producing distorted images when zoomed
Barrel ether missing guiding pin(s) or broken plastic guides. Parts are available only as a whole Zoom Block Assembly.
Mar 18, 2009 | Kodak EasyShare P850 Digital Camera
Blurred pictures
If it's from moisture then once that dries out it will clear up. Otherwise if it doesn't then you will have to send it into repairs and they can clean the internal lens for you.
Jul 31, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Sony Cybershot DSC-S950 Digital Camera Logo
47 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
