Question about Garden
No problem: I need to know the specs of a ceramic tile cutting blade that will fit the Hitachi C7SC circular saw that I possess. Your machine is the best
  • 885 Answers
Any blade 7 1/4" in diameter or smaller with a 5/8" arbor will fit on your saw. Your saw is capable of cutting tile but the dust that will be drawn into the saw by the fan will be very hard on your brushes, armature and bearings severly shortening it's life. Tile saw motors are usually sealed or made to work with water to keep the dust down. Don't use water with your saw, it's not grounded.
Posted on Aug 31, 2010
Wet saw is not cutting square, blade is new but once it hits the tile is shimmies.
Make sure you have the correct blade. There are different blades for different tile. ie ceramic blade for ceramic tile.
Dec 31, 2016 | Blade Saws
I can't remove the blade.
Grip the blade with a pair of vice grips and let them rotate around where they wedge up against the housing, then using the proper wrench remove the keeper nut on the blade.
Jan 10, 2011 | Hitachi Cm4sb2 4" Dry-cut Masonry Tile...
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Does Hitachi C12FCH cut Aluminium?
Hello. A muli-answer for this I'm afraid. The quick answer is yes depending.
Depending On:
  • Thickness of material
  • type of blade
If you are simply wanting to cut aluminum siding/soffit, then install a paneling blade backwards and chop down slowly
If you are referring to bar stock, you will - but not well. You will need a special quick-cut abrasive blade, and you may find you need to change the blades often.
If you wish to cut screen door trim, curtain rod, draft stop, Jolie Edging for ceramic tile, or other thin hollow/extruded materials - then the abrasive blade will do nicely for short/small jobs.
The main problem with cutting aluminum in a high speed rotary device is that the friction of the blade heats the metal fast enough that you get a coating on/in the blade. (In layman's terms - bunged up) The devices in machine shops are set considerably slower, and are usually cooled mainly with liquid.
Hope this answers your question satisfactorily. Good Luck and don't forget to rate this answer.
Thank You,
Richard
May 27, 2010 | Hitachi 12" Compound Miter Saw with Laser...
While using the rz10 tile cutting wheel the saw has no tourque any kind of resistence the wheel stops
The only tile that they are any decent at cutting would be ceramic, slate, or terracotta. Anything else is way too hard and even cutting the listed tile it's no joy to do. I would suggest using a 4 or 4 1/2" grinder with a diamond blade coupled with a wetsaw. hope this helps and good luck.
Mike
Jan 02, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
