Question about Maytag Dryers
How do i get inside to replace belt? - Maytag Dryers
  • Maytag Master
  • 8,220 Answers
Could you post a picture of the dryer for me? They are not all the same. I wrote about a few dryer from maytag:
Amana Speed queen dryer
Crosley admiral dryer
Older Maytag dryer
Posted on Aug 31, 2010
Off and on brush want work
Start by replacing the belts. They should be replaced at least twice per year for proper cleaning. The flat belt will stretch and lose elasticity and the "v" belt wears on the inside grooves. If the smaller narrow inside part of the belt is less than 1/8" it has worn and needs replaced.
Dec 05, 2013 | Hoover Vacuums
How to get inside and replace belt on washer model fws445rbs4 serial xc72602766
To replace that belt,use a flat blade screwdriver and place it between the top edge of front panel and top at the corners and pop up the top,raise the top,inside of the front panel at the top inside corners will be screws that hold the panel to the cabinet,remove those screws and push down and pull off front panel. To replace belt lay on the floor and grab old belt and rotate it off of the transmission pulley and pull it out,place new belt around motor and idler pulley and rotate it around the trans. pulley in a counterclockwise direction
Gene
Aug 10, 2011 | Frigidaire Washing Machines
The rubber band fell off
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes
Mar 27, 2010 | Sony PS-LX250H Turntable
The belt came off
Normally the belt does not go thoough any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes
Jan 28, 2010 | Sony PS-LX300USB Turntable
Belt came off
Dec 28, 2009 | Sony PS-LX250H Turntable
THE BELT ON MY TURNTABLE SLIPPED OFF AND NOW I AM HAVING PROBLEMS OF GETTING IT BACK ON. THE BELT IS NOT CATCHING THE PULLY THAT IT IS SUPPOSE TO CATCH ON TO.
Normally the belt does not go thoough any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes. Move by hand slowly to see waht happens. If the belt slips off again, it may be streched and needs to be replaced
Nov 18, 2009 | Panasonic Technics SL-BD22D Turntable
Replace belts on a 92 nissan 240sx
loosen tensioners using a pry bar or equivalant and loosen tensioners on ac and alternator then tighten when replaceing. work on outside belt off fist and then inside belt off second. then install inside belt first and then outside belt. you will see a grooved hole where the bolt goes through the alternator to reduce tension.
May 24, 2009 | 1992 Nissan 240SX Fastback
REPLACING THE BELT
Hi thanks for the question. to replace the belt. open the door. screws on the inside, under top. remove screws . lift the top. 2 screws on the inside, of front panel. remove. pull front off. now replace the belt. thanks the appliance doc. please rate me. thanks
Oct 05, 2008 | GE DCSR483EA Electric Dryer
Dvd writter is not working
Replace the rubber belt inside. That rubber belt keeps other rotating parts inside to move faster as the motor is running, replaced it with a tight one so that when your insert a cd the optical inside can easily read your cd. The optical lens need to run with as a desired speed of your ROM xspeed.
Put a new gear belt and replace the old and tired belt inside.
Jan 22, 2008 | LG CRD 8120B (CRD-8120B) Internal DVD...
When playing dvd, picture is jerky
the drive needs cleaning
use a DVD/CD Cleaner disk to clean the lens.
Jan 16, 2008 | Artec DHM-G48 (ar16x) Internal DVD Drive
Dryers Logo
128 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
