Question about Refrigerators
I have an APM6855 Fridge / Freezer, which I am having to manually defrost the coil every 2 to 3weeks. Should there be an electrical defrost system of some sort? If yes, what is likely to have caused it to stop working and any adivise on how to fix it?
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
Hygena fridge freezer APM6855. In holiday mode. Freezer ok. Ice in bottom of freezer .fridge not working
Try defrosting freezer. If still not working, you may need to have unit recharged.
Jul 17, 2013 | Freezers
APM6855 that is frost free, Appliance is 5 years old and worked fine for 3.5 years, but now I have to defrost every 3/4 weeks because fridge goes to H (above +9), however I defrosted last night and when...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 14, 2011 | Refrigerators
My fridge and freezer stopped working today, I turned both to coldest setting freezer is working now but fridge is not. What could the problem be?
Greetings,
usually, this means a defrost problem or maybe an evaporator fan not turning. The first thing I would do. Is check to see if the freezer fan is running. if not, the defrost thermostat is most likely defective...(amana seem to all have this problem) the next thing is the freezer coil..The coil may be frosted over to much and air can't circulate thru it..if so, again with this the fan may not be running and the defrost thermostat needs replacing......if fan is running and coil is frosted over...you need to advance this into a defrost and depending on the year...It may have either a manual timer you can advance or an electrical defrost board.....let me know if you need more help, Bruce Denton
Dec 08, 2010 | Amana Refrigerators
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My fridge has ice build-up in the freezer behind the inside wall. this ice is on the freezer elements, because of the buildup, the fridge is not cooling.
This sounds like a problem with the defrost circuit. It is likely that the evaporator coil is clogged with ice due to the defrost heater / circuitry not functioning. This can be caused by a failure of any one or more of the following components:
1) Defrost timer. Defrost timer may be "stuck" - failing to advance from a cooling cycle to a defrost cycle. May be found in the toe space of many fridges, but not all.
2) Defrost terminator. This is a thermal sensor that is secured (usually with a clip) to the refrigerant line close to the evaporator coil in / behind the freezer compartment. If this component fails to detect a rising temperature, it never allows the fridge to return to the cooling mode again.
3) Defroster Heating coil. This is a simple, relatively low wattage heater secured to or near the evaporator coil. It is powered through the defrost timer and shut off by the defrost terminator. If the coil is burned out or otherwise "open", it will not heat to melt ice buildup on the evaporator coil.
4) Fan. The fan is located near the evaporator coil. If the fan is unable move air from the freezer to the fridge, the compressor runs endlessly because cold air is not directed into the fridge compartment - where the thermostat is located.
5) Condenser coil. If the condenser has a "furry jacket" it's long overdue for a cleaning. Gently vacuum lint / dust / dirt collected on the coil to increase efficiency. This is probably not the problem - but it probably needs to be done anyway.
Most of these steps will require hand tools, schematics (specific to your model), electrical test equipment, etc. Be careful to not use sharp instruments that may puncture refrigerant lines or electrical insulation. Allow the ice to defrost with the fridge powered off with the freezer door opened, or place a pot of hot water inside, hair dryer directed at the coil, etc. Access to the evaporator coil is usually from the freezer compartment (back wall) and will require removal of any ice maker installed.
I hope this helps!
Oct 26, 2009 | GE Refrigerators
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
I have a schreiber fridge freezer. Display is showing H for fridge, freezer is ok. Can anyone help? Thanks Anne
APM6855 Built in fridge freezer If Fridge is not cooling & freezer is ok then try a defrost by switching off for 24 hrs Then switch back on. it should be OK. If this does not work it is probably the door switch faulty , this should switch on the fan when door is closed. The fan is then controlled by thermostat sensor which switches fan off/on when required.
Nov 15, 2008 | Refrigerators
Whirlpool fridge
most likely you have defrost problem look for snowy type ice build up on rear wall of freezer side. if its frosted up manually defrost the freezer either by turnog unit off and leaving doors open for several hours or you can remove the freezer cover and defrost the coil with a blow dryer.
the most common part to fail in the defrost system is the defrost thermostat.
good luck
Dec 19, 2007 | Refrigerators
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
