Question about Kenmore 72132 / 72134 Gas Kitchen Range
Gas pressure is low and also oven not lighting
  • Kenmore Master
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 30, 2010
Oven gas slow to warm up
Low gas pressure,governor set too low maybe?
Jan 07, 2014 | Frigidaire FGF316 Gas Kitchen Range
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Gas Range has inconsistent gas flow
From what you've described and what I understand; the only part that requlates the gas flow "low or intermitten gas flow/pressure" is the "gas pressure regulator" located where the incoming gas flex-line connects directly.
The pressure regulator is about 3" x 3" metal square blockish' type device and can be replaced fairly easy. However, if and when replacing the pressure regulator, ensure you are using the proper gas - yellow teflyon tape of pipe dope paste to thread in the new part.
What is the model number of the range? (free standing - gas pilot only)
(The above suggestion is assuming you have the proper gas supply pressure to your home/range)
Jan 27, 2009 | Hotpoint RGB745 Gas Kitchen Range
Not enough gas to range?
you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven & hob taking a long time to come on(on FULL pressure)
Hello mick1939. Are the ignitors the clicking/sparking type or the glow bar type?
If they are the glow bar type, when they get older they don't send enough amps to the gas safety valve thus only letting a small amount of gas to the burners. Try replacing them if they are glow bars.
Nov 30, 2008 | Ovens
Oven Burner
try this,when you see the ignitor glow use a match and try to light the burner itself BE CAREFUL!! if the burner lights the problem is its clogged or low gas pressure.remove the burner and use brake cleaner to clean the burner AND pilot.if your using propane youll have to do this occasionally.let me know.
Jan 04, 2008 | Ovens
Gas burners won't light
I would check the pilot orfices and the regulator on the unit.Seems like not enough gas pressure.Let me know
Dec 10, 2007 | Kitchen Ranges
Oven heat
The problem with you oven is the FFD (flame faliure device ) also known as FSD (flame safety device) The way is works is that when an oven is ignited first time the heat from the low level flame heats phail at the end of the calliary tube which in turn increases the pressure within this tube forcing open the FSD valve to open allowing full gas through. when this fails it restricts the amount of gas flowing through it leaving the oven with a small flame. these are easily repalaced but the law says it must be done by a corgi registered engineer for gas safetey reasons...But 110 % that is your fault. HTH
Dec 04, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kenmore 72132 / 72134 Gas Kitchen Range Logo
133 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
