Question about Black & Decker String Trimmer Cordless 12" 18V
Black and decker string trimmer GL530 runs hot and does little cutting then slows down. Can't seem to disassemble it either. I would like to take it apart and oil it and take any debris out so the motor can run freely but I do not know how to take the head of and how to take it apart. I've looked online but cannot find anything.
SOURCE: Black & Decker 8209 Weed Trimmer
I fixed mine, but this thing won't let me post. If I have to be a member just to make a suggestion, my suggestion would be 'let me post my suggestion'. Do you think everyone passing through here is a member? Some of us would rather not sign up, but still have something to contribute. anyone out there to hear this?
Posted on Jul 20, 2008
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
SOURCE: Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
Posted on Jul 26, 2009
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: Black and Decker gh1000 type 2 string trimmer the
I had the same problem, there is another screw hidden under the black sticker. If you feel around, there is a soft spot. That's it.
Posted on Jun 02, 2010
Black decker problem
This could be a lot of things. One thing to check is the vents on the head. IF they are clogged then it over heats. Another thing is the battery connections and temperature. When it fails take the battery out if you can and see if it is hot.
Jun 26, 2014 | Black & Decker String Trimmer Cordless 12"...
It looks like its working fine, but it doesn't cut the grass. Looks like the string is spinning with the turn instead of against it, if that makes any sense.
If the string is spinning it should cut no mater which way it is turning. maybe you aren't getting the trimmer close enough to the grass.
Apr 17, 2010 | Black & Decker String Trimmer Cordless 12"...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
String is cut always
first of all be carefull of what you hit with the trimmer string if you hit sidewalks and rocks or dirt it will cut it short also you might make sure the tensil strength is strong enough to withstand the abuse the trimmers being subjected to :-)
Jun 22, 2009 | Black & Decker String Trimmer Cordless 12"...
The grasshopper stirng trimmer keeps letting to much trimmer line
i have the same problem. it sounds like your clutch is broken. i went to the hardware store and it seems like a hard piece to find. its unfortunate becuase its the little white plastic piece that should cause on $.99 to replace.
Jun 13, 2009 | Black & Decker 14" Grass Hog Xp...
Jul 30, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
111 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
