Question about Whirlpool LER5636P Electric Dryer
How do i change the belt on my whirlpool dryer ?
  • 155 Answers
Step 1:
Start by removing the lint filter using your 5/16th
screwdriver,remove the two screws under the lint filter.
Step 2:
Next,take the putty knife and place it in the opening between the top of the dryer and the front of the dryer.
Pop up the top of the dryer and repeat on the other side.
Step 3:
Flip the top out of the way.There will be two screws in each upper corner of the inside of the dryer.Remove both of these and put screws in container for later.
Step 4:
The front of the dryer will now be released.Pull the top away from the cabinet and then lift it up.Swing the front to the side and place it out of the way.You may need to disconnect the lid switch wires if they are not long enough to allow this.
Step 5:
Release the belt from around the drum.To do this,the belt will be looped under the idler pulley and then attached to the motor.Reach under the drum and unhook the belt from around the motor.
Step 6:
To attach the new belt,begin by placing the belt around the entire drum.Then loop the belt under the idler pulley and attach it back to the motor.The idler pulley should apply tension to the belt.You may need an extra hand for this step since the dryer drum can sag down and make it difficult to reach the motor.
Step 7:
Make sure the rear felt on the back end of the drum is not folded under.If it has,use a screwdriver to pop the felt out while spinning the drum with your hand.
Step 8:
Reassemble the dryer.Make sure the small tabs on the bottom of the dryer match up with the small holes on the dryer front.Replace screws and lint trap.
Posted on Aug 31, 2010
How to change the belt on a whirlpool AWZ7814 AL
These dryers have common roots with lots of other brands. You should be able to see what you need via either video:
How to Change Dryer Belt on Whirlpool Dryer or in Instructables
How To Replace Dryer Belt on Whirlpool Models
Nov 18, 2015 | Whirlpool Dryers
How to change dryer belt
You have to remove the drum, by disassembling the dryer. That process depends on the model.
Jul 19, 2014 | Whirlpool Dryers
BROKEN BELT Let7848aqo Whirlpool
The belt is a 341241. You can get one on Ebay
How to tuneup and belt replacement
My home movie shows row to replace it:
Sep 05, 2012 | Whirlpool LER5636P Electric Dryer
The belt is broken and we need a replacement for it.
Hi and welcome to FixYa, I am Kelly
Go to any of these sites and enter your model number:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
http://www.repairclinic.com
If you have difficulty locating your belt I need your complete model number and will use those same sites to find your belt for you. There are 2 different sized belts for a whirlpool dryer depending upon the model number. 27 inch dryer and 29 inch dryer.
Download this manual to help you change the belt:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The order of removal is the toe panel, top and then the front panel to gain access to change the belt.
Toe panel (page 15 / pdf file page 20)
Top panel (page 14 / pdf flie page 19)
Front panel (page 19 / pdf file page 24)
Make sure you inspect the drum seals (felts) and the the drum rollers in the process of changing the belt.
The manual link I passed is for the 27 inch dryer but access is exactly the same for the larger dryer.
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Whirlpool Dryers
How to change a belt on whirlpool dryer Model LER4634EQO
Check out this page for good information on changing the belt. Good luck with your repair!
Mar 01, 2010 | Whirlpool LER4634J Electric Dryer
DRUM NOT MOVING ON WHIRLPOOL ELEC DRYER
the belt is off or broken, changing the belt yourself can be tricky, you must remove the front bulkhead and door/panel assy, then you have to route the belt correctly from th motor to the belt tensioner, you may want to call a tech.
Jan 06, 2010 | Whirlpool LER5636P Electric Dryer
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
