Hi, I'm having a problem connecting my laptop to my TV via S-video to RCA cable. I have it connected correctly, hjave tried restarting, but get no video on my TV
I found the problem.
I was connecting it throught an RCA switch box, it worked when I connected directly to the television.
Posted on May 26, 2008
Cable to connect laptop to TV
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
Hi I'm trying to connect my laptop to play photographs through the TV screen using windows XP. No success at the moment. How do I connect up please? And can i get a manual for the TV anywhere...
For making the physical connection between PC and TV first we need video cable.
PC has S-Video port that should be connect to the S-Video input of your TV using S-Video cable.
Connect the computer to the TV using VGA ports or via the DVI to HDMI cable. These Macs need Adapter for a VGA cable.
RCA for audio, connect RCA to your PC and red and white colored sockets of RCA cable to TV (left audio-white, right audio-red).
In your PC open the Display Settings and activate output to the TV screen.
In your TV open the menu from that open the External inputs. And change the video to HDMI depends on the connection.
You can also change the screen resolution of your TV using the Personalize and Display Settings options in your Control Panel on PC.
After giving the connections you can watch the movies and everything is running on laptop on TV.
Jun 07, 2011 | Televison & Video
Connect laptop to TV
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Mar 10, 2010 | Televison & Video
I've been trying to use s-video cable to connect
Mar 06, 2010 | Acer Aspire 3690-2196 Notebook
I have a laptop and a tv. I would like to hook my laptop up to the tv. The tv does not have a slot for a VGA CABLE and my laptop does not have a slot for an RCA CABLE. What can I do to connect the two?
You need an Video out, adapter cable, for your model Laptop, IF yours indeed does have the ability to TV out, the "output" is "Composite Video" and goes into the Composite Video "IN" on the TV. Audio is taken from Line Out in laptop & goes to AV audio in, via a Phono Jack to RCA converter plug. Also it must have correct drivers and be enabled and have desktop extended to the TV either Cloned or Spanned.
Usually one connects up to the TV, powers TV on & then Turn your laptop on.
You may have a Yellow RCA socket on the back/side of your laptop, otherwise you have to get a converter cable.
Feb 07, 2010 | Compaq Presario Notebook
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Acer Arspire 1642 WLMI does the vga output support tv out?
i dont think it has..you can then buy a VGA to RCA for the regulatr TV(should work for both the TVs)
an example is here
http://www.cablesnmor.com/vga-rca-cable.html
please info if u want more help,will be glad..regards
Nov 27, 2008 | Acer Aspire 1642WLMi Notebook
Laptop to tv via s-video
go to your device manager & ,select your display & uninstall the hardware, then you can restart your system with the monitor connected .every thing we be reconfigure correctly
Oct 11, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
No display
Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
Sep 02, 2007 | Philips DVDR3455H/37B
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
